Do you run you're whole clock or shut down before night?
Discussion in 'Questions From New Drivers' started by DAX_, Sep 28, 2017.
  1. DAX_
    DAX_ Medium Load Member
    592
    461
    Sep 4, 2017
    I just delivered in Denver, after picking up in North Texas, woke up the early morning to make the delivery on time.
    Now I had 3 hours left on the 11 and about the same on the 14. After I do so I set my PTA to 7 or 8am in the morning.
    My DM calls me asking why the PTA is so late from now and if I can set it for now instead.
    I told him, it depends on the load and what time they give it to me.
    My question is, is it really a bad thing? I mean pretty much every truck stop in Denver is full right now already, and say it takes them 30-40 minutes to find me a load, ima only end up driving a extra 80 miles or so before my 14 is expired, not to mention probably will have to park on a shoulder or off ramp somewhere.
    If I finish a delivery late in the day(during or after rush hour) I usually set my PTA for the next morning, so I can find a place to park
  3. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    If I have flexibility to run my preferred schedule, and not pushing toward a tight appointment across the country, I'll generally run (drive) 10-10.5 hours, and break for 10 or until I can roll around 04:00 CT.
    But i often run every minute of an 11 if I'm in a region I'm sure I won't have any issues, and have an earlier option if something does go wrong. At about 9-10 hours I'll look at my distance to go and available time and determine if I can make it to plan A or revert to plan B.
    We usually have a slower day or two at some point in the week due to appointment waits, so we're going to get some off time at some point, anyway.
    But usually, I'm running however I have to run to make the appointment on the other end. If there's time to get there early enough to get a restart in a "comfortable spot", then I'll push through hard and get it done. I've done 4 days straight in excess of 10:50 drive time, at all times of the year, and always parked in a truck stop by 17:00. It's not a problem. Having been out here for a long time, you learn what you can and can't get away with in a given region.
    But how you manage your time is ALWAYS dependent on where you're working and the type of hauls you typically do and expect. What works for one driver at one carrier probably won't work for another driver at another carrier.
    born&raisedintheusa and Lepton1 Thank this.
  4. Balakov100
    Balakov100 Road Train Member
    3,937
    2,637
    May 10, 2012
    Temple, TX
    It really depends every load is different.
    I do like running my 11 almost out and taking a 12-14 hour break.
    But too many factors really.
    What time will you shut down after driving 10:55h.
    Is there going to be parking available.(Location and timing)
    Lepton1 Thanks this.
  5. mpd240
    mpd240 Road Train Member
    1,540
    3,623
    Sep 17, 2011
    Minnesota
    With elogs maximizing my 14 hours everyday is what works for me.
  6. Dave_in_AZ
    385,698
  7. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,757
    Sep 20, 2014
    That's the right answer, and the reason I don't like to communicate with messages that don't communicate much info.
    If they are doing to bounce you to somewhere where you can load and park for the night at the dock or on the street in front of it, I'd want to move. If they are going to bounce you a distance away, I'd want to be moving in the right direction. If they want you to load back up in Denver, at a place where they will take 2 hours to load and expect you to leave with no time left on your clock, it's not happening.
    Lepton1, RedRover, mindes and 2 others Thank this.
  8. IluvCATS
    IluvCATS Road Train Member
    4,091
    8,976
    Dec 1, 2014
    Seattle, WA
    You need a friend or mentor or just an experienced hustler who knows how to work the clock. The goal is to make money right? It has taken me a while to manipulate my time used, hustle, bend corners, sleep at shippers, combine on-duty tasks, etc. so that I'm getting more loads than others. I have a friend in my company who has been here 8 years and always helps me figure out how I can get a load in on time. Get empty and get a head start on my next load.
  9. ChaoSS
    3,338
    6,757
    Sep 20, 2014
    In the company is good. Different companies work differently, different dispatchers work differently. You need to learn to work with your company and dispatch system to maximize your miles.
    Some people don't care to maximize their miles, and if that's you, then it is what it is.
    I will say this to the OP, you posted this at what, 5 local time? And you put your PTA at 7 or 8? That's 14 hours off, and a late start to the day. I'd put the PTA at 3 in the morning if you don't want to keep moving right now, that way you can get the early morning loads rather than waiting until traffic is getting bad to get started on your way over to shippers who are already getting behind on loading other trucks.
    Lepton1, BB203 and IluvCATS Thank this.
  10. supersnackbar
    19,108
    47,104
    Aug 19, 2007
    Your Town, USA
    I always offer them an option..."will only have xx hours on my 11 and xx on my 14 once I am empty, so unless my next pickup is close and fast, set my pta for morning"
    DAX_ Thanks this.
  11. Moosetek13
    Moosetek13 Road Train Member
    14,663
    18,419
    Nov 1, 2010
    Burnsville, MN
    You are lucky to find a space to park in Denver on any day, or at any time of day.
    I usually reserve a spot at the TA in Commerce when I am headed there, just to be sure.
    If I had 3 hours left to work with, and if the load was pre-loaded, I would take it and then go back to my reserved spot. A live load? No way.
    But to set my PTA for 'now' without knowing any more details, no.
    And I would not be planning to drive out of Denver with so little time on the clock.
    I do NOT park on ramps or the side of a road for any reason. And that would be the only option out of Denver in any direction with so little time. Everything near enough at that time of day is taken.
    Reserved parking can be your friend at times.
