Double nut spindle axle nut setup
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, May 12, 2019.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    I've taken this setup off of trailer in renting. Is there missing hardware? What keeps outside nut from loosening up?
    From left to right inner nut, ring, outside nut
    Cattleman84 Thanks this.
  3. Cattleman84
    Cattleman84 Road Train Member
    10,039
    71,756
    Nov 1, 2017
    The Sticks, Idaho
  4. Goodysnap
    Goodysnap Road Train Member
    3,774
    9,202
    Jul 12, 2017
    The locking device is a small Allen screw in the washer/spacer with the holes in it. That's what small threaded holes are.
  5. mitmaks
    2,586
    2,102
    May 16, 2014
    There were no Allen screws. Does anyone have diagram of setup?
  6. Goodysnap
    3,774
    9,202
    Jul 12, 2017
    You can get a new washer with new locking screws. People dont see them and force them off shearing the screw off.
  7. Pedigreed Bulldog
    7,737
    14,424
    May 7, 2011
    The inner nut is the important one. Get that one set. Then you put the washer on to lock that inner nut in place. Tab in the slot on the spindle keeps it from spinning, and the knob on the inner nut fits into a hole to lock the inner nut in place. If the hole doesn't QUITE line up, try flipping it over. If they're still off, back that inner nut off as little as neccessary to get the knob in a hole. The outer nut only gets torqued to 50 or so ft lbs...only thing it does is hold that lock washer against the inner nut. It won't go anywhere.
  8. homeskillet
    homeskillet Road Train Member
    6,343
    49,171
    Jun 1, 2013
    Dayton, OH
    This is a very common set up on bus axles.
    You are missing a big star washer that has a tongue to fit the groove in the spindle, same as the lock ring.
    It goes on after the lockring and before the outer nut.
    After final torque of the outer nut, you peen over at least two of the tabs on the star washer. That is what holds the outer nut in place.
    mslashbar and mitmaks Thank this.
  9. mitmaks
    2,586
    2,102
    May 16, 2014
    I've replaced it with stemco pro torq
    homeskillet Thanks this.
  10. BoxCarKidd
    BoxCarKidd Road Train Member
    4,552
    6,642
    Aug 26, 2014
    That is an old tried and true set up. The allen set screws came out much later. I do not use them as I believe those were for liability against ambulance chasing attorneys. Installed correctly the nuts are locked together and do come loose.
    There are several discussions about wheel bearing adjustment in the top right search block.
  11. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    There's a notch on the spindle.
    The inner nut has a little pin which faces outwards. Tighten the inner nut until it's almost snug. Align the washer so that the tab on the inside of the washer slides into the notch on the spindle and the pin on the inner nut goes inside one of the holes on the washer. The washer will prevent the inner nut from turning. Put the outer nut on and torque it down to the torque specification which is probably more than a hundred and fifty pounds. It's just like doing an F-350 spindle nut except probably bigger. I got something similar on my Chevy Tahoe.
