Dry bulk or flatbed
Discussion in 'Questions From New Drivers' started by Chebbydriver7195, Mar 16, 2019.
  1. Chebbydriver7195
    Chebbydriver7195 Light Load Member
    113
    121
    Feb 24, 2019
    Maverick USA told me I'd never pass a physical, but I have a dot medical card and a cdl.
    I have a "bad" left leg.
    Over a year ago I was shot in the leg while hunting. It left me with permanent nerve damage causing foot drop. I wear a brace and you'd never tell unless you looked hard at how I step. I just cant pick my left foot up, can push down with full force and can still balance.
    I tried to get my cdl with Maverick USA but they stopped returning my calls when I asked about their company physical. I'm now with a mega pulling van but would like to pursue my original ideas of flatbeding or equipment haul after I get say another 10 months of experience.
    If that isn't viable could I pull a dry bulk tanker with my condition? My dot physical has no restrictions or limits. I was a log cutter for a while even after my injury. If I can tromp through the woods and climb on trees with a saw I can climb up on a trailer.
  3. Humblepie
    Humblepie Pontificator
    5,077
    80,318
    Dec 25, 2018
    If you can buck logs you can be a flatbeder. Kudos for not taking no for an answer.
  4. TruckerVinny
    TruckerVinny Medium Load Member
    375
    253
    Dec 10, 2015
    Bulk is pretty physical. During loading and unloading I'm on top of the tank, under the tank, throwing hoses, crawling under rail cars and in/out of the cab several times. If you are able to rock then let's roll. Call a recruiter once you hit 12/mths or try sooner, they can only say no or tell you to wait. Good Luck!
  5. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    I think with your attitude you could do either. Just make sure you have the right equipment. For example, for flatbed I like to have a short ladder to make it easier getting up and down different parts of the trailer. I also prefer ratchet binders over snaps.
  6. kemosabi49
    10,674
    45,812
    Jan 13, 2013
    SW Arkansas
    As long as you can go up & down the ladder You should be able to do tanker, liquid or bulk.. Or flatbed. Go for it.
