Dry van to tanker? Opinions?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by kt_themvp, Feb 21, 2022.
  1. kt_themvp
    kt_themvp Bobtail Member
    6
    4
    May 1, 2021
    Wassup people. KT. 24. Chicago based.
    Rookie here gonna get straight to the point. Just got my CDL class A 3 months ago. Been driving for 2 months so far. I’m a regional dedicated driver in the Midwest. Hauling 53’s & 28’s depending on my route. I plan on driving dry van for 2 years than switching over to tanker. (Maybe sooner depending on my confidence) I have hazmat, tanker, doubles & triples, TWIC card & no restrictions on my license. Nervous about manuals but will drive one (hence the no restriction). How is the surge in a tanker manual vs automatic? Increased following distance? Any tips or insight on the change in my plan? Thank you
  3. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Check out Nomadic-Brit on youtube. He is leased on to Schneider and runs tanker. A lot of good info in his videos.
    Munch75 and kt_themvp Thank this.
  4. tscottme
    tscottme Road Train Member
    Good plan. I would start looking at employers when you have 1 year of experience. Just drive like the state trooper is riding in the passenger seat with you. ALWAYS be at or below the advisory speed for on/off ramp curves and the surge is nothing to be afraid of. The surge feels like getting kicked by Godzilla when you first start moving if you slam the throttle. It's not dangerous then. As you gain speed the surge feels less frightening but becomes more dangerous. You can only make a panic stop going straight ahead and you have to keep applying brakes even after you stop because the product stops a few seconds after you do.
    The surge is nothing to be afraid of, if you drive properly, and it is nothing to be ignored. Few people regret pulling tankers, it's much better than dry van. Better customers are the best part as far as I'm concerned. They are easier to back and park than a van or reefer.
  5. Cat sdp
    Cat sdp . .
    20,942
    72,812
    Apr 8, 2012
    Orion's Belt
    Not all tanks are smooth bore . Multi compartments and baffling cut down on the surge. Plus being able to fill the tank helps too………
    Long FLD, kt_themvp and pathfinder1361 Thank this.
  6. kt_themvp
    6
    4
    May 1, 2021
    Thanksss
  7. kt_themvp
    6
    4
    May 1, 2021
    Thankss
  8. wis bang
    wis bang Road Train Member
    3,386
    3,981
    Jan 12, 2011
    Levittown, PA
    Tank Yanking requires a smooth driving style. You need the ability to stay focused on
    (1) getting the load [sometimes harder than one would think] then
    (2) hauling the load. Surge is always there but is controllable to the point where it is just part of life going down the highway. and
    (3) getting the tank empty without contaminations, spills, etc..
    Gotta be a little bit a plumber, little chemist and just all around ready to do stuff you never connected to trucking.
    You also need to understand what PPE is and how it protects you from some gruesome damages when you do haul that load of Bad Stuff [PC/PG13 version]
    Gearjammin' Penguin and kt_themvp Thank this.
  9. RockinChair
    RockinChair Road Train Member
    5,067
    12,775
    Feb 19, 2012
    CC, TX
    KT, you've got the right idea. You definitely need more following distance with a tanker, and you need to go slower around curves and corners too. And if you can become experienced shifting a manual transmission before you make the jump to tankers, it'll probably be an easier transition for you, that way you don't have to learn manual shifting and surge control at the same time.
    kt_themvp Thanks this.
  10. Dave1837
    Dave1837 Road Train Member
    1,399
    4,342
    Nov 16, 2019
    Pennsylvania
    The surge is sometimes that becomes a part of you once you get used to it. If I pull anything but a tanker I feel lost because I don't get that bang starting out from a red light. Definitely want a manual to pull any smooth bore tank, autos suck. I usually start in 2nd, skip 3rd, by the time I'm going into 4th the surge is coming forward so it goes right in gear. Skip 5th to 6th then the other 4 gears shift normal. That's on a basic 10 speed. Once you pull a tanker you won't want to pull anything else, they're easy and unless you're hauling specialty/food grade there's really no waiting around like with vans.
    RockinChair, tscottme and kt_themvp Thank this.
  11. haz-matguru
    haz-matguru Road Train Member
    2,882
    4,392
    Feb 18, 2012
    Western international gas
