Eaton 10spd splitter procedure
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Sep 19, 2023.
  1. mitmaks
    mitmaks Road Train Member
    2,564
    2,077
    May 16, 2014
    When I'm in high range and driving let's say 60mph and if I click splitter down, am I supposed to hear it or not until I'm slowed down enough for low gears?
  3. Big Road Skateboard
    6,319
    35,107
    May 2, 2021
    Why would you be going into low at 60?
    Last Call, Stay Puft, Oxbow and 4 others Thank this.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,518
    9,826
    Mar 30, 2014
    10 speed except super 10, do not have splitter. Only range, which you should be under 20 when going to lo range.
    bjytech, BoxCarKidd, Oxbow and 2 others Thank this.
  5. mitmaks
    2,564
    2,077
    May 16, 2014
    Ok thanks. If I'm at high speed can I still hear it clunk into low range if I select range?
  6. Broke_and_Hungry
    Broke_and_Hungry Light Load Member
    225
    515
    Feb 26, 2008
    The range selector only shifts while in neutral, you will not hear the transmission shift (clunk) while in a gear. IMHO, it would be foolish to play the the range selector at high speeds.
  7. Big Road Skateboard
    6,319
    35,107
    May 2, 2021
    Never tried it and ain't gonna. You could seriously damage the synchronizer and sliding clutch doing that.
    Last Call, bjytech, Stay Puft and 3 others Thank this.
  8. Jubal Early Times
    3,069
    20,583
    Oct 17, 2022
    Only when you move the stick to neutral.
  9. Opus
    124,452
    I sincerely doubt you could put it into gear at that speed. The high low won't engage until you go to neutral. If you wanted to, you could ride down the road all day long flipping it up and down and nothing will happen until you take it out of gear.
  10. Big Road Skateboard
    6,319
    35,107
    May 2, 2021
    Yes, out of gear is what I thought he was talking. Just range shifting in neutral at high speed can definitely cause damage.
    In gear, no. There is a detent spring and pin in the slave valve that keeps air from moving unless the shift forks are in neutral
  11. AModelCat
    160,839
    There's an interlock on the range of every Eaton-Fuller transmission I've encountered so far. Unless the shift rails are in neutral the air should be blocked from going to the range piston. That's why preselecting a range shift is no big deal.
    You can try it with the truck shut off. Put the stick in any gear and cycle the range lever, then move the stick back to neutral and you should hear it complete the range shift.
    Oxbow and mitmaks Thank this.
