How much have you found your ECM to be off, compared to hand figures? Reason I ask, my old T600 is doing good by the Scangauge that's hooked up to it. Even if its off a a good Percent. The series 60 11.1 is still doing good. Truck holds 475 gallons of fuel. Is a factory single axle. Direct 10 speed, 2.93 rearend, 295/75R22.5 tires.
Pete
ECM MPG vs hand figuring?
Discussion in 'Ask An Owner Operator' started by tnpete, Dec 8, 2018.
I figure by tank to tank, that’s the most accurate.
My 2000 T2000 had a ‘lifetime’ MPG in the dash that was fairly close to correct. -
M8ne is off more during the summer. Probably because I idle more, and it only counts fuel burned during driving?
My 2013 Western Star was off by 5 percent.
My 2016 Cascadia is within 0.025 of a mpg.
It depends on the truck, tire wear, etc -
Thanks guy's, mine is showing high. Empty last Friday it showed 14.2 MPG. Loaded coming back, but only 16,000 lbs of Pellets on pallets. 12.7 MPG. This was driving 55 almost the whole 4 hours. Not much in grades to pull. Did not come out of 10th gear, unless turning .
With the 4 tanks, hate to fill it up. I only run it part time. And will be a while before I fill it up. Thinking about shutting off three tanks. Then fill one, but hate to let 400+ gallons set around in the tanks. 1995 KW T600.
I know we got unreal MPG on the 11.1's around 93 to 95. Ran From tn to LA,OR,then Miami and back to Tn each week. Almost pulling an empty trailer, both ways. And one Qtr we averaged 11.3 MPG. Trucks were set at 68 MPH, We ran team 6800-7200 miles per week.
The same Condo FLD120's with the same gears but 12.7's. high 7's low 8's same trips. We got a new truck every Qtr. -
I do my own math and it’s tank to tank.
Camping world had the kr edition on sale last month so I picked one up. The one I have read a little over two gallons high right out of the box. Only ran one truck with the Detroit readout it was pretty close.
I have a regular Scangauge. I can go into the settings and have it do a percentage adjustment on the mpg reading.
So when you do the math by hand and over several fillings get an idea of how far off the gauge is. You can enter that difference as a percentage and get a more accurate Scangauge reading.Rounded_nut and magoo68 Thank this.
