Electric problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Master of trouble, Jan 11, 2025.
  1. Master of trouble
    Master of trouble Bobtail Member
    Jan 11, 2025
    “Help”
    Hey guys I have a problem and not sure where to start.
    Patient record; 1998 Peterbilt 379,12.7
    I replaced the turn signals with the LED 4 weeks ago,last week when I unhook from my log trailer I lost my rear running lights and brake lights, dashboard lights and the headlights went from dem to hi beam as soon as I plug the pig back in everything works. Any help would be appreciated.
    blairandgretchen Thanks this.
  3. blairandgretchen
    13,657
    74,288
    Dec 9, 2011
    South west Missouri
    Sounds like more problems than just the change from incandescent to LED flashers, but -
    Change your flasher relay to a LED flasher relay - the old ones rely on a bi-Metal strip that heats and cools , the LED have much lesser draw, thus lower heat generated to activate the heat/cool cycle of the bi-metal relay.
    beastr123 Thanks this.
  4. Ridgeline
    22,630
    120,522
    Check your Grounds!!
