electronic logs question #2
Discussion in 'Questions From New Drivers' started by zoekatya, Jul 15, 2014.
  1. zoekatya
    zoekatya Medium Load Member
    397
    99
    Mar 15, 2013
    How come when I go take my ten hour break it says I have 8 hours drive time when the ten hours isn't even up yet? Like nownitnsays I have 8 hours but I've only been in the sleeper 9hs and 37 min? If I were to start driving would I break the law? Or would it be legal and it just wouldn't give me another eight hours when I took my half hour break between the third and six hour driving( I believe it is)
  3. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    910
    Mar 16, 2013
    Breaks within the first 8 hours. That's the whole point of eight hours. You'd have to take a 2 hour break. It's called a split. Don't try it unless you know what your doing.
    zoekatya and tow614 Thank this.
  4. tow614
    tow614 Road Train Member
    3,759
    4,630
    Mar 18, 2013
    It is actually a flaw in the system that they still have not corrected...and yes..the split sleeper can be confusing the way the rule is written now.
    zoekatya Thanks this.
  5. FwL
    FwL Medium Load Member
    438
    331
    Aug 30, 2011
    Sandpoint, ID
    Why do you say it's a flaw in the system?
  6. tow614
    3,759
    4,630
    Mar 18, 2013
    This has been a debate on here before but the qualcomm elogs makes the mistake of extending your 14 hr clock after a 2 hr break which it is not supposed to do. Only an 8 hr break extends the 14 hr clock by the 8 hrs but no more.
  7. NewNashGuy
    NewNashGuy Road Train Member
    1,616
    752
    Jul 27, 2011
    US and Canada
    You drive a truck and dont know about the 8/2 split?
  8. loose_leafs
    loose_leafs Road Train Member
    1,294
    1,468
    Jan 3, 2014
    Old Man River, MN
    lots of drivers dont, and some drivers and even DOT will try to say it's illegal until you rub the reg in their face
    TwinStickPeterbilt and zoekatya Thank this.
  9. purpleprime
    purpleprime Medium Load Member
    681
    720
    May 30, 2013
    spickard, mo
    There is no flaw in the quallcomm it is giving him hours back because it has showed an 8hr sleeper however if you leave before your ten you will have to take a 2 hour off duty break some were down the road to get all of your hours back but I agree with previous comment don't use the 8/2 split unless you fully understand it
    zoekatya and Cranky Yankee Thank this.
  10. tow614
    3,759
    4,630
    Mar 18, 2013
    You are correct except the 2 hr break does not extend the 14 hr clock.. this is where many drivers get into trouble.
    zoekatya and blairandgretchen Thank this.
  11. reuter19
    reuter19 Light Load Member
    82
    31
    Dec 17, 2013
    Took me awhile to figure the 8/2 out and would never use it on paper logs. Bound to #### it up. Also only use it if you need to get somewhere within the time you gain back. Otherwise you only save 30 mins
