What type of electronic logs does knight use? I am familiar with swifts qualcom because of a friend so I'm hoping that ill be able to just jump right into that but....
For you drivers out there what is in the trucks?
elocronic logs?
Discussion in 'Knight' started by j.a., Jan 31, 2016.
Zonar system.
Is it a tablet??? If I just looked it up and saw what I saw then thats amazing!!!!
Yeah it's a 8" tablet. It's a bit slow and has some bugs but once you figure it out it's not so bad.
The main problem to watch out for is the GPS which is set to avoid toll roads and only take truck routes. You want to double check the route on your phones GPS either Google or Apple maps, then triple check the satellite view to make sure the shippers address exists and it matches what you see on the zonar then you are okay to go. I still don't trust the GPS completely and use common sense when I think it's giving me bogus directions.scottlav46 Thanks this. -
Sweet thanks alot man, its similar to the qualcom so I think ill get used to it pretty quick.
Dude that's awesome advice that's what I do too, you put it really well.
Don't get mad at the electronic logs.....get mad at the silly hours of service rules that we have to follow.
Marky84 Thanks this.
