Elog and bobtail questions
Discussion in 'Questions From New Drivers' started by Drpparker95, Oct 24, 2017.
  1. Drpparker95
    Drpparker95 Road Train Member
    1,445
    321
    Jan 2, 2017
    Meridian mississippi
    I have to ask because my instructors at school don't know alot about elogs. What happens if you're on you're 10 and you wanna bobtail to the store to get groceries or something. For arguments sake no uber or taxi service available
  3. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Assuming you meet the FMCSA guidance, company policy and ELD programming allows it, then it can be done as personal conveyance. Some ELDs have it as a "line 5" option.
    Question 26: If a driver is permitted to use a Commercial Motor Vehicle (CMV) for personal reasons, how must the driving time be recorded?
    Guidance:
    a driver is relieved from work and all responsibility for performing work, time spent traveling from a driver’s home to his/her terminal (normal work reporting location), or from a driver’s terminal to his/her home, may be considered off-duty time. Similarly, time spent traveling short distances from a driver’s en route lodgings (such as en route terminals or motels) to restaurants in the vicinity of such lodgings may be considered off-duty time. The type of conveyance used from the terminal to the driver’s home, from the driver’s home to the terminal, or to restaurants in the vicinity of en route lodgings would not alter the situation unless the vehicle is laden. A driver may not operate a laden CMV as a personal conveyance. The driver who uses a motor carrier’s Commercial Motor Vehicle (CMV) for transportation home, and is subsequently called by the employing carrier and is then dispatched from home, would be on-duty from the time the driver leaves home.
    A driver placed out of service for exceeding the requirements of the hours of service regulations may not drive a Commercial Motor Vehicle (CMV) to any location to obtain rest.
    - Regulations Section
  4. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    True,, but if they have a trailer ...
    Using the information that is in the interpretation above and in the definition of “on duty” and the corresponding interpretation found in Section §395.2, the following conditions of personal conveyance can be extrapolated.
    • The vehicle must be unladen.
    • Movement is of a “short” distance solely for personal use.
    • The driver is relieved from work and all responsibility for performing work.
    • The driver is relieved of all duty and responsibility for the care and custody of the vehicle, its accessories, and any cargo or passengers it may be carrying.
    • The driver must be at liberty to pursue activities of his/her own choosing.
    • No work should be done until the driver is ready to return to duty.
  5. Drpparker95
    1,445
    321
    Jan 2, 2017
    So if im understanding you can bobtail to stores or restaurants in the area so long as we're not talking excessive distances
  6. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    You do understand what "bobtail" means?
    Mudguppy and tinytim Thank this.
  7. Drpparker95
    1,445
    321
    Jan 2, 2017
    Bobtail would be truck and no trailer
  8. Hoofbeats
    Hoofbeats Road Train Member
    1,250
    1,991
    Jan 27, 2010
    Iraq
    Yes, because it would be difficult to understand without yelling.
    I'd imagine that you would have to start your ten hour break on line one,off duty. I don't think you could do it if you started your break on line two without out falsifying your logs. The elogs may even move you from line two to line one and keep you there.
    RedRover Thanks this.
  9. kemosabi49
    10,901
    47,291
    Jan 13, 2013
    SW Arkansas
    Also will depend whether your company allows this. Not all of them do. It is their truck.
  10. scottied67
    scottied67 Road Train Member
    10,826
    12,673
    Mar 14, 2010
    california norte
    If you're a company driver most likely the company will not give you the option to move your tractor unless it is logged Drive time.
    If you're a lease op or owner op, you could do it and even transport alcohol in your tractor off duty unladen.
    A21CAV and SingingWolf Thank this.
  11. Drpparker95
    1,445
    321
    Jan 2, 2017
    Got you I'll have to ask the trainer or ask at orientation
    ladr Thanks this.
