Embarrased to ask a HOS question at this stage, but....
Discussion in 'Questions From New Drivers' started by Pmracing, May 16, 2013.
  1. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    my daily 11 hours is a combination of lines 3&4, correct?
    Two other company drivers are telling me they can drive 11 and are legal to go to line 4 for another three. The on duty hours falling in the middle of their 11, not at the start or end of the day. As would be expected doing drop and hooks, loads and unloads.
    But I can not specifically find it in the regs.
    Edited:
    Let me clarify my situation.
    Is it legal if I drive 7 hours, lump freight 3 hours on line four, then drive another 4 hours? Meaning I have been "On Duty" for 14 straight hours. No "off duty" or "sleeper berth" logged at any time during that 14.
    I was under the impression that the only way to extend my eleven hour window is logging line 1. (aside from irregularities like split sleeper, 16 hour rule and other oddities.)
    Mikeeee
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    you are allowed 11 hours total in line 3. Those HAVE to be completed in a 14 hour window though.
    That's really the only "time limit" for the day.
    ETA....
    Other than having a 10 hour break BEFORE starting your 11 hour driving.
    Pmracing Thanks this.
  4. Evil_E
    Evil_E Heavy Load Member
    790
    537
    Nov 25, 2011
    Dexter,MI
    ^^^ yep
    Someone correct me if I'm wrong....but technically you could drive 11 hours then go to line 4 for as long as you need to. Just have to have 10 hours off (line 1 and/or 2) before you can drive again.
  5. scottied67
    scottied67 Road Train Member
    10,826
    12,671
    Mar 14, 2010
    california norte
    What I did on paper logs was make a small mark at the time I started the clock then counted over 14 hours and made another mark-- cannot drive past this mark nor drive (line 3) more than 11 hours within these marks.
    You can be on line 4 as much as you want, even past your 14.
    It is very important to keep it legal because a violation may cause you to work your next ten loads for free paying the violation off.
  6. Ghost Ryder
    Ghost Ryder Road Train Member
    1,647
    1,182
    Jan 3, 2013
    Your Mailbox
    No sir, your daily 14 hr clock is a combination of line 3 and 4, not the 11.
    Example:
    You drive 6 hrs to a shipper and spend 7 hrs loading. After 3 hrs, your 14 hr clock will start eating away at your 11 hr clock. If you drive again after you get loaded, you will get a log violation on your 14 hr clock.
  7. kirk
    kirk Medium Load Member
    373
    139
    Jan 15, 2009
    ks
    Only 11 hrs of driving, and 14 hrs on duty.
    Pmracing and ClassB Thank this.
  8. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Only thing to watch out for before driving again, if you use a lot of L4 time is 'The 70'
  9. hhmag70
    hhmag70 Light Load Member
    103
    59
    Mar 18, 2012
    Trevorton,Pa
    That is correct. You could lump a load for 24 more hours and get paid on line 4 but cannot drive again until you have your 10 hour break.
    RickG and Pmracing Thank this.
  10. ITS62
    ITS62 Light Load Member
    164
    69
    Apr 29, 2011
    Gilroy, CA
    Assuming you are staring fresh off a 10 hour break, once you go "on duty" that starts your 14 hour clock. You can "drive" for a maximum of 11 hours within that 14 hour window. You can no longer drive if you A) are "driving" for 11 hours or B) run out of your 14 hour window, which ever comes FIRST. How much on duty/off duty/sleeper is irrelevant and can be broken up into as many chunks as needed.
    So if you go "on duty" at 12:00 noon, you can drive for 11 hours OR 2 am whichever comes first.
    Once you are done driving, you can stay "on duty" till the cows come home and work for 48 hours straight...you can just not drive again until you have a 10 hour rest period (splits excluded)
  11. MNdriver
    7,985
    4,372
    Feb 24, 2012
    You got it.
