Engine/alternator noise on radio
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Buckeye91, Oct 15, 2013.
  1. Buckeye91
    Buckeye91 Road Train Member
    1,095
    677
    Sep 26, 2011
    Midwest, USA
    I just got into a 2010 pete 386. Got my satellite radio hooked up, and noticed that the engine noise goes thru the radio. Also, if I plug my phone into the radio with the 3.5 aux cord, it doesnt make the noise, but, if i plug my phone into the car charger port at the same time as in the radio, it makes the engine noise. This leads me to think that its coming from the charger port. Anyone know how to fix this?
  3. NewNashGuy
    NewNashGuy Road Train Member
    1,616
    752
    Jul 27, 2011
    US and Canada
    This is referred to as EMI (electromagnetic interference). It was a big problem back in the day when everything was analog. They used to have filters for this. I actually had a similar problem so I just bought a separate battery and hooked my radio to it. I use the cig lighter to charge the battery while driving.
  4. blairandgretchen
    13,266
    70,890
    Dec 9, 2011
    South west Missouri
    Back in the day (!) I would use an inline noise suppressor, not sure where to find them anymore.
    Have you asked on the cb radio forum? Sure those boys would know.
  5. NewNashGuy
    1,616
    752
    Jul 27, 2011
    US and Canada
    Yes I bought those at Radio Shack back then. You could find them everywhere lol.
  6. kasandera
    kasandera Bobtail Member
    30
    Nov 3, 2012
    Are you running a power inverter ? We found that was the issue in a Pete 387.
  7. wilfredbacon15
    wilfredbacon15 Light Load Member
    277
    50
    Sep 29, 2013
    Manila, Philippines
    I also read about that, that there was an issue in Pete 387 about power inverter. I don't know if there have a solution for that.
  8. kasandera
    30
    Nov 3, 2012
    Sine wave invertor can eliminate some or all the noise
  9. Buckeye91
    1,095
    677
    Sep 26, 2011
    Midwest, USA
    No inverter yet. I will look at radio shack for the noise suppressor when I get home Friday. Where does this hook up at?
  10. ThatFlatbedGuy2013
    ThatFlatbedGuy2013 Medium Load Member
    591
    119
    Feb 4, 2013
    Somewhere in the US of A
    Try replacing the audio cable. A broken wire can also cause the issue.
  11. vanapagan
    vanapagan Light Load Member
    75
    53
    Apr 29, 2013
    Merrick, NY
    Check your grounding of the radio. If the grounding is good and the condition still continues the you may need to add a small bi-polar capacitor (usually 0.47 uF) between the radio's power wire and the ground wire. A good reference is http://www.dieselduck.net/machine/03 electricity/radio_interference.htm while it is oriented to marine machinery the concepts apply to your truck.
