Engine not workign good when parking brakes are on VOLVO 780 D13
Discussion in 'Volvo Forum' started by Pawel-pl, Feb 25, 2020.
  1. Pawel-pl
    Pawel-pl Bobtail Member
    47
    18
    Jul 3, 2017
    Hello,
    I noticed that when on parking with brakes on my truck is not working as good as when with brakes off. With parking brakes on the RPMS are shaking little bid and the engine is working much harder and louder. As soon as I turn off the parking brakes all is good and back to normal. There are no codes on the engine
    Did you anyone had a similar issue or maybe any idea what could be the cause?
    Volvo vnl 780 D13 with Ishift
  2. Scooter Jones
    Scooter Jones Road Train Member
    7,783
    14,804
    Apr 19, 2011
    What happens when you you bump the throttle up on CC switch?
  3. Pawel-pl
    47
    18
    Jul 3, 2017
    Same thing, RPMS shaking little bid and engine is working harder. The only thing that is changing it that I found is the parking brake when it's on the whole thing happens, when off engine works great.
  4. Deere hunter
    Deere hunter Heavy Load Member
    712
    1,830
    Aug 5, 2017
    I can’t be reading this right you’re trying to drive it with the parking brakes on?????
    x1Heavy, magoo68 and Dave1837 Thank this.
  5. Pawel-pl
    47
    18
    Jul 3, 2017
    When on parking with brakes turned on there is the issue, when on parking with no breaks turned on there is no issue, when driving all is good, no codes at all
  6. Dave1837
    Dave1837 Light Load Member
    257
    505
    Nov 16, 2019
    Pennsylvania
    Wow lol I can't be reading this right
    x1Heavy and Deere hunter Thank this.
  7. Cattleman84
    Cattleman84 Road Train Member
    3,473
    12,954
    Nov 1, 2017
    The Sticks, Idaho
    Sounds like it has been left in gear... Did you move the shifter to neutral before setting brakes???
    Deere hunter Thanks this.
  8. Pawel-pl
    47
    18
    Jul 3, 2017
    Yes I did
  9. beastr123
    beastr123 Road Train Member
    1,055
    10,461
    Jan 2, 2014
    Moose Jaw SK CAN
    Sounds like the engine is trying to get ready to REGEN the dpf.
    It needs to get the engine temp up to do the REGEN and will change the timing to make the engine work and generate more heat.
  10. x1Heavy
    x1Heavy Road Train Member
    32,866
    38,556
    Mar 5, 2016
    White County, Arkansas
    I am having trouble with this.
    I can also have alot of fun with this. But I'll just leave it alone today.
    Deere hunter and QUALITYTRUCK Thank this.
  • Draft saved Draft deleted
