Engine Odometer vs Total Engine Run Time when buying a truck?
Discussion in 'Ask An Owner Operator' started by sooopertrucker, Apr 25, 2019.
  1. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    Some guys just LOVE to idle.
    Had to move from a knothead the other day.
    55° and a good breeze.
    He had his windows down and idling away.
    I gave him the benefit of the doubt for a while.. he cut it off and went inside.
    Came back out... cranked it right back up.
    I get it if it's hot or cold... you have to run a CPAP and don't have an APU..
    But some are just addicted.
    I like the peace n quiet.
    roshea and TallJoe Thank this.
  3. tarmadilo
    tarmadilo Road Train Member
    1,736
    4,783
    Dec 12, 2018
    Why are truck prices about to drop?
    blairandgretchen Thanks this.
  4. Ridlingdj
    Ridlingdj Medium Load Member
    414
    562
    Dec 12, 2018
    I would get the one with less hours on a truck that new your filter will plug up sooner with soot
  5. blairandgretchen
    14,019
    77,336
    Dec 9, 2011
    South west Missouri
    A flood of folks that got into business last year on soaring rates, going out of business this year as rates stagnate in the toilet.
    Just a guess.
    tarmadilo Thanks this.
  6. Accidental Trucker
    Accidental Trucker Road Train Member
    3,448
    7,861
    Jun 4, 2015
    If you know the pedigree of the truck, then you can determine if it's idling or, for example, PTO work like unloading a tanker or walking floor, or something else PTO driven - we run a fish pump with our PTO, which is about 40% of the engine time. There is a little load on the engine (25 hp in our case) and it runs at 1,100 RPM's, but that would still put a load on the after-treatment system, if it had one.
    In my opinion, the best odds with a used EPA engine truck would be one with as much long distance highway miles as possible (less stress on drive line components), serviced at the "heavy duty use" interval, and operated by a team. I suspect that lots of cold starts are probably as bad as lots of idling, if not worse.
  7. Cummins
    Cummins Bobtail Member
    4
    Worcester
    I’m with you.
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    The one truck we had as a team, a 2000 freightliner we put about 7500 hours on the detriot OTR as a team. 5500 of those hours were putting away the miles that year in 10 months 221000 total. 2000 of that would be idletime give or take a little bit. About 60+ hours a week. We never shut it off. We did run high idle. 1100 or so most of the time and a few extreme winter situations at -55 we would be idling at 1500 set. There was no emissions anything in those days to worry about. Just a automatic transmission that required a shut off 30 days every 7 days per manual. Otherwise it will brick and you needed a tow.
    Regarding the prices, miles etc I don't know. Those computers should be able to be pulled from those engines and generate a chart that detailed it's habits to the Nth degree.
