Evaporator Drain tubes routing/location on carrier Reefer
Discussion in 'Refrigerated Trucking Forum' started by Dionicio0911, Aug 31, 2019.
  1. Dionicio0911
    Dionicio0911 Bobtail Member
    5
    7
    Jul 15, 2019
    just bought a Reefer trailer with a carrier 2100A unit. Having problems with it getting to -5 degrees. I think the evaporator drain tubes are clogged up causing the evaporator to consonantly ice over. I’ve ran wire in the tubes no luck with that. I opened the front drain hole on the trailer floor and there is lots of ice . I’m guessing the water from defrost is leaking back into trailer. I have a load on it now. What is the best approach to seeing if the tubes are disconnected or clogged from beginning of the evaporator? Thanks
    bzinger and KB3MMX Thank this.
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,471
    Nov 7, 2007
    Possum Booger, Alabama
    pull the tubes off where they connect to the evaporator box and let it run a defrost cycle. Wear gloves... the refrigerant lines by the battery side drain will be hot.
  4. lilillill
    5,642
    13,471
    Nov 7, 2007
    Also, what year is the box? Were you able to get it below -5 previously?
  5. Dionicio0911
    5
    7
    Jul 15, 2019
    It’s a 2011, and yeah got it down to -10 before we bought it. I’ll try disconnecting the tubes. I see water on wall draining down inside the engine compartment when it’s defrosting but it’s very little .
    KB3MMX Thanks this.
  6. Dionicio0911
    5
    7
    Jul 15, 2019
    It worked!!! I pulled the lines at the top out came a flood!! Top of the lines were clogged with leaves and junk. Probably from me trying to blow air into them to make sure they were clear pushed it all to the top and packed it! Thanks a bunch man!
  7. lilillill
    5,642
    13,471
    Nov 7, 2007
    Clean the hoses out and make sure there are nipples on the ends. The evaporator will suck warm air up the hoses if there aren't.
    The nipples will also prevent mud daubers from building nests in the tubes.
  8. SalT
    SalT Bobtail Member
    Hi. We have a thermo king and we believe are having the same issue where water is slowly draining inside the trailer wall on defrost and then leaking down the middle of the unit from the front. Has anyone experienced this with a thermo long. This only happens on defrost.
  9. reeferwrencher
    reeferwrencher Medium Load Member
    560
    1,480
    Aug 4, 2018
    It happens on all reefets if the defrost drains clogged. Just clean em out you should be fine .
    bzinger, KB3MMX and Buckeyes614 Thank this.
  10. Buckeyes614
    Buckeyes614 Light Load Member
    148
    153
    Jan 22, 2014
    Does having a clogged drain tube prevent the unit from cooling properly to -10?
    How exactly do I clean the tubes out?
  11. reeferwrencher
    560
    1,480
    Aug 4, 2018
    Pull the hoses off then go in back of trailer and remove evaporator panel.CLean out any plastic and debris under the evaporator coil.You will find 2 holes there stick a screw driver or coat through them and clear out.Go back to front of unit and clear hoses with coat hanger,put hoses back on.Get a container of water and dump it under the evaporator, make sure water is running out of hoses. Yes it will cause it to not cool properly because the water stays in the trailer and immediately freezes after it completes a defrost cycle and then blocks air flow over the evaporator. Good luck
