So I picked up a load on Monday. Everything was routine. Their loading dock has one of those black covers around it and the yellow rectangles on the sides to target in the trailer as you back in. So after it's loaded I pull up to close the doors, and I look and see a hole punched into the corner above the tail lights and two flaps of bent steel out of the hole. I go back to their dock and see a big threaded rod sticking out under the black canvas of the dock cover which is what punched the hole in my trailer. Obviously a previous driver tweaked the frame of the cover and I guess nobody has noticed yet.
Realistically, I could hammer it all down and rivet a piece of aluminum angle over the hole. It just ticks me off because the trailer is brand new without a scratch on it, at least until now.
Ever charge a shipper for damage to your trailer?
Discussion in 'Ask An Owner Operator' started by SteveScott, Nov 28, 2018.
Page 1 of 3
It's gonna happen. It happened to me about 3 weeks after I bought my own trailer. Not the same thing but similar. They'll never pay but you could try it if you have the time and energy to pursue it. I bet the best that will happen will be that they fix the dock, which is still better than nothing.
Rideandrepair and PE_T Thank this. -
A shippers yard truck backed into my nearly brand new van trailer with his fifth wheel raised up high and punched 2 holes in the sheet metal skin. They wanted to pay for a $100 patch job but I was not having any of that with a brand new trailer. At a cost of $1,100 the entire sheet metal panel was replaced and they did pay for it. I documented everything with lots of photos, got the shipper to admit their fault, and being leased to a good company where the owner had dealt with these sort of things many times over the years, he knew how to get them to pay. It was a couple of months as I recall but they sent a check.
Rideandrepair, whoopNride, 86scotty and 4 others Thank this. -
When going into those types of docks, always get out and look.
201 and blairandgretchen Thank this. -
I had damage to my flatbed from a careless forklift driver.
The shipper took photos, we swapped details - they were very squirmy when it came to paying up.
3 months later I finally got a check out of them.Rideandrepair, whoopNride, Ruthless and 2 others Thank this. -
Yes, if a shipper or reciever damage the equipment. A report is made at the location the damage occurred.
Usually let the insurance companies haggle it out.
It can take a few months to get a settlement.Last edited: Nov 29, 2018
Rideandrepair, whoopNride, MM71 and 4 others Thank this. -
Rideandrepair, MM71 and Cattleman84 Thank this.
Rideandrepair Thanks this.
If you damage their property, Should they think Twice about billing you?Rideandrepair, whoopNride, 86scotty and 1 other person Thank this. -
Rideandrepair and TallJoe Thank this.
Page 1 of 3
