Extensions for diesel fill up?
Discussion in 'Questions From New Drivers' started by JoeF2002, Jan 14, 2016.
  1. JoeF2002
    JoeF2002 Light Load Member
    165
    119
    Dec 31, 2015
    Saylorsburg, PA
    Hey guys - I was wondering if any of you have seen filler extensions for when you go to fill up the gas tanks. Not common, but I've read on some various posts about people who have difficulty reaching the gas caps or putting the fill nozzle into them due to obstructions. I don't think this will be a problem for me, but I was curious: if the gas cap is obstructed or just hard to get to, are their temporary extenders you can place into the fill hole for refueling purposes? Thanks!
  3. ajohnson
    ajohnson Medium Load Member
    580
    1,368
    Jan 6, 2016
    chicago area
    Not to be rude, but no gas, diesel.
    You can buy a flexible funnel of any length if you want, but I have never had any trouble putting it in the hole.
    lagbrosdetmi and JoeF2002 Thank this.
  4. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    The only place that would be a benifit to it is small "car" gas station where the diesel pump is only on one side and not long enough to reach the passenger side tanks.
    When I use to do local, I would had to fill one tank, then drop the hose and spin the truck around to fill the other side.
    JoeF2002 and ajohnson Thank this.
  5. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    A few trucks have the fuel openings in such a place as to make it hard to get the nozzle to settle in in a way that it tays securely without possibly "falling out". These are rare. But any extender would have to "screw in" to lock and this would only put it in closer proximity to whatever was in the way in the first place making it then impossible to get the nozzle in.
    And you can't add an extension to the nozzle else the auto cut-off would be rendered ineffective and you'd end up with over-flows.
    JoeF2002 Thanks this.
  6. 59MackB61
    59MackB61 Light Load Member
    196
    165
    Sep 12, 2012
    On some trucks I have seen the tanks roll up from off road work. Just loosen the tank strap and pull the tank back into place then tighten again
    Sometimes need to replace the rubber between the tank and strap
  7. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    If the nozzle doesn't seem to hold in the right place while pumping diesel into the tanks, many drivers, including me have extra bungee cords nearby to secure the filler hose handle in a safe position while fueling.
    ncmickey and White_Knuckle_Newbie Thank this.
