Hey all. So Ive been trying to get into Old Dominion and I had a road test this morning. Failed cuz I couldnt do the brake test, ya know the "fan the brakes till the knobs pop out," etc. Failed it cuz I havent done it in 6 years since I did my test at the DMV. Told my buddy about it thats been at Transport America for 12 years or so and drivin for 20 and he said "yeah I havent done that in 20 years." They said study up and be back next Monday same time.
So my question is, does anyone have any advice on where to study back up till then?
Failed road test cuz I failed brake test
Discussion in 'Experienced Truckers' Advice' started by Marky84, Jun 25, 2018.
Using the link below assuming Wisconsin. You will find the format under 5.3.3 on page 5.5:
http://wisconsindot.gov/Documents/dmv/shared/bds356-cdl-manual.pdf
I have always viewed it as 4-60-40
Air leakage rate not more than 4psi in 1 minute
Low air warning activates at 60psi
Spring brakes activate below 40psiMarky84 Thanks this. -
Wow, I'm amazed a company made you go that far in a road test. I'm also kind of surprised you haven't done a brake test in that long. I always do one when I get in a truck I haven't driven before. But I cheat, I just let the emergency line hang loose, and push the valves in and watch for when the warnings start and when the valve pops out. Then fan until the other valve pops out. I think the test is in the CDL test manual. If not, I'm sure there are videos on youtube. Just check the sources. Good thing they're giving you another chance.
They gave you a second chance, that means you're not washed out.
Read the CDL manual
Trucker61016, G13Tomcat, x1Heavy and 2 others Thank this. -
If I wanted to work where you work, I'd pass your test. I said what I said, because in my experience, companies don't do all of that. Some don't even road test at all. At some point, a driver's experience and record should speak for itself. I resent being tested for some things, to some degree. I used to work at OD, my road test consisted of hooking to a pup, and driving around the block. It took five minutes, no pre-trip at all. I didn't even drop the pup when we got back.DTP Thanks this. -
To the op, they gave you another chance thats great! You'll get it next time no problem. Ive heard good things about OD you'll like it there. -
You will demonstrate that test anytime you have a Level 1.
I can offer you my clip board professional driver.
wore out, Dark_Majesty_06, ArmyGuy and 3 others Thank this. -
G13Tomcat Thanks this.
