Faul codes for 2012 frieghtliner cascadia, cummin ISX 15.
Discussion in 'Questions From New Drivers' started by Jaleer99, Apr 18, 2021.
  1. Jaleer99
    Jaleer99 Bobtail Member
    8
    Mar 13, 2015
    Houston,TX
    Here are the codes.
    -Check engine light with these codes.
    -ENG 0
    -SPN 3218
    -Fail 2
    Any help is will be appreciated
  3. Frank Speak
    Frank Speak Road Train Member
    4,519
    13,821
    May 3, 2016
    If it has oil, has coolant, cranks and runs down the road, run the #### out of it.
    If you stop that truck every time the #### check engine light comes on, you’ll go broke.
    firemedic2816 Thanks this.
  4. Jaleer99
    8
    Mar 13, 2015
    Houston,TX
    the check engine light and codes came after I have jump start the truck because inverter drained batteries.
    slow.rider Thanks this.
  5. Moose1958
    Moose1958 Road Train Member
    15,167
    33,405
    Dec 17, 2010
    Williesburg, Virignia
    Hand! Anything throwing codes needs to be looked at! There are more computer sensors on today's trucks than Carters has liver pills. One such sensor is not happy and as soon as you can get it looked at. I can't find any information online about fault code 3218. As long as the truck is running ignore it but make dang sure you write it up as soon as practical.
    firemedic2816 and Jaleer99 Thank this.
  6. Arctic_fox
    4,072
    21,130
    Sep 16, 2016
    With a rig that old you should be able to grab a code reader pretty easily that can check and clear codes. While i know it doesnt help right now. It may be worth picking up. Half the codes an engine throws are things you can do yourself with a $20 walmart tool kit and some elbow grease. Even i can usually puzzle out how to fix things and i have all the mechanical skills of a drunk stoned spider monkey with a brain injury.
    Jaleer99 and SoulScream84 Thank this.
  7. Jaleer99
    8
    Mar 13, 2015
    Houston,TX
    I'm at the shop now for diagnostic. Will update the finding. Thank.
  8. bzinger
    bzinger Road Train Member
    16,613
    65,929
    Dec 10, 2014
    omaha , ne
    I have the same truck and engine as you ....its when the 2nd check engine light comes on that you need to be real worried.
  9. Ridgeline
    22,394
    116,374
    There should be a 3228 code with that one, it is the NOx sensor problem, more likely the power supply module that I think the 2012 has is toasted by jump started.
