Fifth wheel slide questions
Discussion in 'Questions From New Drivers' started by road_runner, Jan 29, 2013.
  1. road_runner
    road_runner Road Train Member
    3,501
    8,994
    Mar 26, 2012
    Montucky
    I got a piece of junk old truck that I am driving. The fifth wheel slide is pretty dry and rusted up and will sometimes not move when I try to adjust it. I have to hammer the dogs back that lock into the slide to get them to lock/unlock. What is a good lubricant to keep things moving smoother? Will some WD40 work? Or should I find some grease similar for what we use to lubricate the top of the fifth wheel? Also, when is the best time to slide the fifth wheel? Landing gear up or down when the trailer is connected?
  3. Joker85
    Joker85 Road Train Member
    1,465
    331
    Jul 3, 2010
    Phoenix Az
    Trailer down, unlock fifth wheel lower air bags
    road_runner Thanks this.
  4. Chinatown
    Chinatown Road Train Member
    74,625
    169,619
    Aug 28, 2011
    Henderson, NV & Orient
    Sometimes with those dirty, rusty ones, lower the landing gear enough to take some weight off the fifth wheel. Sometimes WD-40 helps.
  5. Moosetek13
    Moosetek13 Road Train Member
    14,656
    18,402
    Nov 1, 2010
    Burnsville, MN
    Trailer connected, landing gear down and just touching.
    Then drop the airbags.
    Sliding should be easy from there.
    What is a good lubricant?
    WD40 might be good to get things moving, but that 5th wheel grease will keep it that way.
    road_runner and Chinatown Thank this.
  6. KMac
    KMac Road Train Member
    3,427
    3,067
    Jan 26, 2012
    Waxahachie, TX
    To get it moving, don't even bother with WD40... get some PB Blaster. And then use the 5th wheel lube.
    keepitsimple Thanks this.
  7. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    If the pins won't slide out easily, perhaps the slide has been used so much that it has worn down the metal. raise the height by slipping pieces of metal under the fifth wheel slide and weld the metal to the plate that is attached to the frame. This will let the slides open up easier as they will not be binding anymore. (If you have a holland slide where the air cylinder is just in front of the 5th wheel and it pushes the locking pieces outward to unload the slides.) For lubrication of the slides, I have used hub oil, wd-40, and just about anything else you can name, thought the gear oil worked good, Chainsaw bar oil wasn't too bad, sometimes it depends on how dusty and dirty the environment is where you run.
  8. Balakov100
    Balakov100 Road Train Member
    3,937
    2,637
    May 10, 2012
    Temple, TX
    Try to find the Sweet Spot and just leave it.
    123456 and STexan Thank this.
  9. 123456
    123456 Road Train Member
    10,555
    5,746
    Oct 22, 2010
    32179
    Really !!!
    I can't see moving the 5th wheel very often......if at all.
  10. road_runner
    3,501
    8,994
    Mar 26, 2012
    Montucky
    I pull both pups and long boxes. I move it towards the back for clearance on the landing gear, and then I need to move it forward to get a bit more weight on both my axles here in the winter time. I rarely screw with it in the summer time.
    123456 Thanks this.
  11. Mrh2008
    Mrh2008 Road Train Member
    1,288
    310
    May 25, 2012
    Mesa, AZ
    Neither can I. I've moved the 5th wheel one time in nearly a year.
