If I roll onto a scale one axle at a time and write down the difference in weight how do I figure the third axle weight the tandems? Thank you in advance.
Figuring individual axle weight off of a cumulative scale
Discussion in 'Questions From New Drivers' started by Bisket, Feb 18, 2017.
Page 1 of 3
Write down all three totals as you get them
The first is your steers,
The second is Drive + Steers, Subtract the Steers.
The third is Gross, subtract the second total and that is your tandems.SingingWolf, ExOTR and Hammer166 Thank this. -
If it's easier, number the weights 1 2 and 3
Steers = 1
Drives = 2 - 1
Tandems = 3 - 2
Gross = 3 -
To double check your trailer, pull the tractor off and leave the trailer on the scale by itself to verify your subtraction was correct.
Steers- 12,000
Tractor- 46,000
Drives- 46,000 minus 12,000 = 34,000
Total Unit- 80,000
Trailer- 80,000 minus 46,0000 = 34,000
Pull tractor off and leave trailer on = 34,000
All Good.not4hire, tscottme and Moosetek13 Thank this. -
Do they not teach basic math in schools these days?
Roberts450, noluck, SingingWolf and 4 others Thank this. -
It's a pain in the ### but saves you $10.50 and an unnecessary stop.
mindes Thanks this. -
And if you're at all familiar with your equipment, you can tell right off of the shipper's scale is vastly out of calibration. In most instances, they'll work for your needs.Last edited: Feb 18, 2017
noluck, passingthru69 and MachoCyclone Thank this. -
What is the third axle in the the tandem? There are two axles in a tandem, do you mean third axle on the truck?
To answer what I think is your question: Overall for most trucks and trailers the weight load on the tandems is evenly split by both axles of the tandem. Their are exceptions, but most in general divide the load up evenly.
Page 1 of 3
