Filled up fuel now won't start -Detroit diesel 60 series
Discussion in 'Kenworth Forum' started by Airman89, Sep 26, 2016.
  1. dave26027
    dave26027 Road Train Member
    1,284
    804
    Sep 10, 2009
    Dallas, Texas
    Most likely one tank ran dry and you lost your prime. You'll have to run it off starting fluid till it primes itself. Could be a bad check valve in the fuel return line behind the head, a leaking fuel filter(sucking air) or a broken fuel pump gear. Don't use too much starting fluid, it will crack a piston.
    Bean Jr. and Airman89 Thank this.
  3. Hulld
    Hulld Road Train Member
    2,883
    6,567
    Oct 19, 2015
    Upstate NY
    My 14 liter Detroit has a mechanical primer pump off the back of the air compressor.
    Airman89 Thanks this.
  4. Hulld
    2,883
    6,567
    Oct 19, 2015
    Upstate NY
    If it has a Davco filter you can remove the top cap and fill it with diesel and it will help prime it....
    ShooterK2 and Airman89 Thank this.
  5. supersnackbar
    19,163
    47,343
    Aug 19, 2007
    Your Town, USA
    If it doesn't have the clear Davco, you'd have to drop a fuel filter an fill it with diesel. Watch using ether, too much and it screws your compression rings up, then it won't want to start without it. We always had 2 people, one cranking the engine (with a foot on the throttle 3/4 full) and the other shooting short bursts of ether until it re-primed itself.
  6. Airman89
    Airman89 Light Load Member
    148
    15
    Jul 8, 2015
    Thanks for the advice everybody. My phone died a while back and I just got it charged so I'm going to try filling the filters and see if that helps. I'm trying to avoid the ether and use a minimal amount
    thejackal Thanks this.
  7. Airman89
    148
    15
    Jul 8, 2015
    No fuel primer or davco by the way
  8. Dave_in_AZ
    387,745
    If the filters are empty, yea you need to remove and fill them lol. You could pump the primer handle til your eyeballs fall out if the filter is empty. I would do that rather than trying to crank it and prime it with ether.
    So its almost 24 hours later, what was it?
    starmac and Airman89 Thank this.
  9. Airman89
    148
    15
    Jul 8, 2015
    Everyone was right. I must have ran it too low and it sucked air in. I only had to give it two small shots and she ran great, and is still running.
    I do have a sputter at around 1500-1650 rpms though. I've had it since I got it. Could this be lack of fuel? Weak fuel pump?
    Dave_in_AZ Thanks this.
  10. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    If it's a mbn 2004 or so cat it's common some series 60 do the same
  11. Airman89
    148
    15
    Jul 8, 2015
    Yeah t has a 60 series Detroit in it. Only seems to do it when it's in 8/9/10
