First Day At TTCC
Discussion in 'Questions From New Drivers' started by terryg247, Jun 22, 2015.
  1. terryg247
    terryg247 Light Load Member
    268
    133
    Feb 1, 2015
    Ontario, Canada
    After wanting to drive truck forever I finally took the plunge and after waiting two months for the physical to clear today was my first day at TTCC in Sudbury. Well I jumped right into the driving portion due to the school sessions being offset due to other programs. First off I have completed all of the written already which was a pain in the butt but it is done and over with. So the instructor went through all of the various air tests and then showed me how to complete a circle check and what to tell the examiner, theory being you will do it so often it will be second nature at my test at the end of July. Then he drove to a part of Sudbury that had very little traffic and before I knew it I was sitting in the drivers test. I have driven standards in the past and part of me wishes I had not as it would have made the switch easier. The main problems I am having is I push the clutch in way too far when shifting, was wearing steel toes while driving and going to try sneakers tomorrow to get a better feel and try sitting farther away from the steering wheel, and basically slapping the shifter instead of using my whole hand on the shifter which is a habit from driving standard cars. Anyway the first day was overwhelming as there is so much to process at one time however with more time spent behind the wheel and going through the variety of air tests and circle checks hopefully it will all fall into place
  3. FozzyNOK
    FozzyNOK Road Train Member
    2,460
    3,789
    Jul 18, 2007
    Oklahomistan
    You should get to that point, but it would be best to understand why you are doing these tests and what their purpose is. I think that the school will also do this, but don't be so sure. The in cab air brake portion of the test is one of the if not THE hardest part of the CDL test for a lot of people.
    One of the things that people do not understand is that a lot of the CDL training is breaking bad habits that the drivers have obtained over the last decade or so since they took their regular car license when they were 16-ish. This is normal and the first day or so is the worst! Your skill and comfort level will take off pretty soon and you'll do better. You will do a lot better if you have peers who are in the truck and sharing the experience.
    Both will help, the lighter shoes especially. I have suggested to people who show up wearing heavy boots on the first day to wear the lightest shoes they own, high top sneakers work pretty well if you have some. Wrestling shoes are fantastic.. but look pretty silly.
    You should be using a light "fingertip grip" on the shifter and hand position is very important. When you are trying for the gears nearest you, you should have your hand on the outside of the shifter so you are pulling the gearshift toward (you) and the gears you want. When you try for the middle two gears, hand directly on top of the shifter and when shifting the far gears, try pushing the shifter away from you and toward the gears on the outside.
    Best of luck to you! Try to think of this as a game of skill, at first everyone sucks at them.. you get better the more you try.. BUT if you get frustrated or angry... take a breather and get your sense of humor back. I relate learning this to tying your shoes.. no real effort now, but when you were learning.. your parents were ready to flog you!
    hal380 and terryg247 Thank this.
  4. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    Where did the phrase, "drive truck" originate? Some sort of longing to be a preppy ivy league frat boy that "rows crew"?
    I drive a truck. I deliver a load. I didn't marry "wife", I am married to my wife!
    Mikeeee
    austinmike and Macneil Thank this.
  5. terryg247
    268
    133
    Feb 1, 2015
    Ontario, Canada
    2nd Day - Well I thought we would be headed back to the deserted part of the city and I would have been very wrong. Instead after running though the air checks, pre-trip and uncoupling the trailer we headed on to the highway. Thankfully I was shifting a whole lot better than the first day but have a whole lot of more work to do. Anyway we traveled on the highway for a good half hour before heading right into the city. After a couple of laps around a rather busy part of the city before heading back to the school
    What I need to work on
    - I tend to forget what gear I am in and end up screwing up when it is time to downshift, going to try talking to myself out loud until I can memorize the gear pattern.
    - Skipping gears, pretty much related to the first area to work on, as I tend to panic when I missed a gear then try to force it into the next gear
    - Downshifting is a bit troublesome in the lower gears as I understand the clutch, rev to 1500 rpm, then clutch again however the speeds in order to match the movement of the truck are still a bit confusing
    The purpose of this thread was basically to chronicle the journey from complete newbie to licensed driver which would not only give me a way to track my progress and gain helpful advice but to also help other people in my shoes dealing with the steep learning curve of driving a truck. Thanks again Fozzy for your help
  6. flyguy35
    flyguy35 Light Load Member
    109
    47
    Apr 3, 2015
    Are you driving a 10 speed? I received this piece of advice from an experienced driver. Above 45 mph you are in 10th, when you get to 45mph you go to 9th, 4+5=9, at 35mph shift to 8th, 3+5=8 etc. Though I have not tried this sounds interesting.
    TROOPER to TRUCKER Thanks this.
  7. terryg247
    268
    133
    Feb 1, 2015
    Ontario, Canada
    13 speed. Interesting advice. Thanks
  8. Pmracing
    6,354
    3,178
    Jan 28, 2011
    I never learned what speed is a specific gear. Always just kind of knew by road speed. There were a few, or a couple few times I mis-judged. And when climbing a steep hill the road speed changes pretty quick. Not much time for second chance choosing a gear.
    I never wanted to be reliant on looking at the speedometer while watching traffic.
    Mikeeee
    terryg247 Thanks this.
  9. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    The biggist thing i tell new blood when the "panic i need a gear now!" Kicks in is, relax, when you learning, and light, (empty or bob) you dont always need a gear RIGHT NOW. You have a few seconds, a play with the clutch, or a dab of go pedal to match rev to road. Remeber your a big truck, people exspect you to be slow and anoying. Dont disapoint, they can go around. Even empty your moving 13 or more cars worth of weight around.
  10. Macneil
    Macneil Heavy Load Member
    711
    426
    Dec 15, 2010
    Sudbury, ON., Canada
    I would not worry about skipping gears just yet. Worry about getting all of your gears(you'll learn road speed vs what gear to kinda be in) better this way. Good luck out there! Sudbury drivers can be pecker heads!
  11. terryg247
    268
    133
    Feb 1, 2015
    Ontario, Canada
    Thanks for all of the advice. Right now it is definitely about becoming comfortable with the shifting process and remembering exactly where I am in terms of the gears. Sudbury drivers definitely have their moments and you would think with a big truck with student driver plastered on it that they would just get the heck out of the way.
