First reefer load
Discussion in 'Refrigerated Trucking Forum' started by CasinoGal, Oct 18, 2013.
  1. CasinoGal
    CasinoGal Bobtail Member
    47
    14
    Jan 28, 2012
    Maryland
    We are getting loaded with our first reefer load of frozen cakes, pies and pastries going cross country. Very little reefer training, just handed a incomplete printed off manual. Our question is, should we use start/stop mode or continuous mode? Our temp is at -10 while they are loading.
    Thanks
    DoneYourWay and Skydivedavec Thank this.
  3. Tobytob
    Tobytob Light Load Member
    129
    154
    Aug 17, 2013
    When in doubt always run continuous! Being that your running frozen pastries I would probably set the reefer to start stop as that stuff won't melt or go bad between temps. -10 is frozen so that trailer would have to get pretty hot for it to go bad.
  4. CasinoGal
    47
    14
    Jan 28, 2012
    Maryland
    Thanks so much for your help!
    Skydivedavec Thanks this.
  5. buzzarddriver
    3,756
    11,149
    Feb 1, 2011
    Dallas, TX
    Loading pre-frozen pastries, you can run start/stop. Your temp variable will be less than 5 degrees. No need to waste reefer fuel. That is if your unit is capable of easily maintaining -10.
    Just make a habit of every time you stop and get out, check the temp, to ensure there are no problems. Should you develop a fault/problem, the product will maintain a frozen state for 4-6 hours if the doors are not opened.
    DoneYourWay, CasinoGal and Lilbit Thank this.
  6. CasinoGal
    47
    14
    Jan 28, 2012
    Maryland
  7. STexan
    STexan Road Train Member
    14,963
    29,158
    Oct 3, 2011
    Longview, TX
    The bills will often state what the shipper "wants" as far as mode. If not, at -10 I would err on the safe side and run continuous at current cross-country temps, but then again if I had a newer unit I would not be concerned with running on cycle-sentry, either. If some of the product just came off the line, it would be wise to run continuous for 6-10 hours to insure a consistent deep cold as the warmer product slowly comes into equilibrium with the set temp
    CasinoGal, heyns57, g.o.a.l and 2 others Thank this.
  8. pusherman
    pusherman Medium Load Member
    358
    149
    Jun 23, 2013
    shipper or broker will generally tell u what temp to put it on & start/stop aka cycle or continuous.
    Lilbit, DoneYourWay and CasinoGal Thank this.
  9. Winkjr
    Winkjr Road Train Member
    1,804
    614
    Oct 18, 2011
    Marlton NJ
    Set it and forget it
  10. BuckeyeCowboy63
    BuckeyeCowboy63 Medium Load Member
    495
    291
    May 28, 2013
    Cincinnati, OH
    I pull refers use stop and start the whole time. I pull refers. Only way continous is ice cream at -20
    GITRDUN45, DoneYourWay and CasinoGal Thank this.
  11. CrossettDriver
    CrossettDriver Light Load Member
    273
    162
    Sep 18, 2012
    Jamestown,NY
    frozen loads I always ran continuous, dident see the point in the reefer turning on and off all the time, imo its easier on the unit to keep it running
