flagstaff to phoenix
Discussion in 'Experienced Truckers' Advice' started by ercan978, Aug 14, 2014.
  1. ercan978
    ercan978 Bobtail Member
    36
    Jun 29, 2014
    Burnsville , MN
    I am a new driver..I need an advice about a route that I ll be driving..I got a 30000 pound load and I have to got to phoenix AZ..I ve heard there are lots of hills and curvy roads on I 17..between flagstaff to phoenix..can I get any advice what should I be avare of in this route or whats the safest way to pass these mountains...thank you
    blairandgretchen Thanks this.
  3. liteguy
    liteguy Light Load Member
    69
    20
    Sep 1, 2009
    you will have no issues going down 17 to Phoenix, heed the warning signs and take it slow, there r some up and down grades but its a good route.
    Snowshoes Thanks this.
  4. streetglider
    streetglider Medium Load Member
    564
    611
    Aug 21, 2011
    Alabama
    be very careful once you pass sunset point, there is a steep grade till you get to black canyon city and it is very curvy, no runaway ramps either. make sure you are in the gear you want before hand.
    Snowshoes and ercan978 Thank this.
  5. ercan978
    36
    Jun 29, 2014
    Burnsville , MN
    Driving a 13 speed..which gear should I choose?
  6. Snowshoes
    Snowshoes Heavy Load Member
    878
    664
    Sep 23, 2012
    Pleasant Grove, Utah
    I used to take that stretch allot, like stated above, heed the signs, remember your training, lower gear, about 6th or 7th and STAY there, and use the jake the way it is intended you will be fine.
    ercan978 Thanks this.
  7. blairandgretchen
    13,241
    70,619
    Dec 9, 2011
    South west Missouri
    The old rule of thumb is the gear you climbed in, or one lower.
    I'd imagine 10th or 11th - Jakes on high, play it cool - don't get over confident. There's a few steep grades.
    Check your brakes at the pull outs before descending.
    ercan978 and Snowshoes Thank this.
  8. coolrider101nk
    coolrider101nk Light Load Member
    50
    41
    Mar 24, 2008
    You can go down any mountain to slowly many times and not worry about it.....flag isn't one to go down to fast even once. Not many chances to decide to down shift once gravity gets you.
    Kickstand-117 and Snowshoes Thank this.
  9. Snowshoes
    878
    664
    Sep 23, 2012
    Well said!
  10. coolrider101nk
    50
    41
    Mar 24, 2008
    Also....as with most down grades in Arizona...... there is one curve that the caution speed is meant for a motorcycle with a death wish....not a truck. Sorry I forget the milepost, but you'll notice it.
  11. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    Idon't like it, busted my radiator on I-17N, pulling heavy reefer loads,and in winter time the higher elevation close to Flagstaff is getting messy ,ice snow, crashes and closed many times. As long as I'm paying my maintenance bills , I keep off I-17; I use it with light loads only,; usually I take US54 from I-40 Santa Rosa ,NM to. I-10 El Paso or Las Cruces. About 100 miles longer but safer and less pressure on equipment.
