Floating Gears
Discussion in 'Questions From New Drivers' started by Kannonball, Sep 14, 2015.
  1. Kannonball
    Kannonball Bobtail Member
    49
    13
    Apr 29, 2015
    Under the Hood
    I'm a rookie driver having trouble learning to float gears. In Truck Driver Training I was taught to double clutch. In training now with first driving job and the company and trainer require being able to float gears. Grinding gears is killing me and bothering my trainer. Any and all suggestions are greatly appreciated.
  3. TROOPER to TRUCKER
    TROOPER to TRUCKER Anything Is Possible
    7,674
    12,737
    Dec 15, 2014
    Charlotte, NC
    It is the same in every truck..listen to it up shifting and down shifting, nobody is perfect at it and still grinds gears. I will come
    Kannonball Thanks this.
  4. MACK E-6
    49,124
    228,732
    I personally think one should learn how to do it the right way before one learns how to do it the wrong way, which you apparently have.
    Since you've learned to double clutch floating will come fairly easy with practice. Knowing your truck's powerband helps to establish your shift points.
    One thing I would caution you on that there are times when you will still need to use the clutch in the course of normal driving, such as taking off obviously, and shifting on a hill where the weight of the truck will act on the driveline and you will have to push the clutch in just to get it out of gear.
    SOG, Kannonball, pattyj and 2 others Thank this.
  5. MACK E-6
    49,124
    228,732
    Not necessarily. Trucks and heavy equipment are like women. Every one is different because they all have their own quirks and gripes.
    No offense, ladies. :)
  6. Patronas01
    Patronas01 Light Load Member
    132
    79
    Dec 23, 2014
    California
    Well I thought that is why you have a trainer. To teach you.
    Ask him to teach you how to float.
    No matter what people will tell you in here, you are going to learn only if you have someone to show you in a Truck. Up sifting should be easier to learn then down sifting but after few months with practice you should be fine.
    If you have a good trainer it should be easy. Good luck.
    SOG and Kannonball Thank this.
  7. Milkman719
    Milkman719 Medium Load Member
    596
    403
    May 29, 2013
    Colorado Springs
    I work a company that has slip seating (we are only out for 1-2 nights) I like the truck I'm in now (Pete) but it sucks when backing up because it surges because its a automatic
  8. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Its easier to learn when your running light, there is a natrural fall out point for each gear. As your speeding up you can let off the gas a bit and give the stick a push and it should fall out of gear clean. A little gas and a LIGHT touch for the next gear. Takes practice. And everything affects it. Load weight, enginge fan, jake, hills.... all will change the behaviour of the truck
    gonejpn and Kannonball Thank this.
  9. RoadRooster
    RoadRooster Road Train Member
    4,121
    6,709
    May 10, 2015
    Fort Myers, Florida
    turn the Jakes off when you're going up through the gears. they tend to knock your rpms down before you can complete the shift
  10. okiedokie
    okiedokie Road Train Member
    12,533
    94,529
    Jun 13, 2011
    PNWET
    If you can DC you can float. It's the same truck right, so the RPM split is the same.
  11. street beater
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    One more thing. Do NOT focus on rpms. They will kill you. Work more with knowing your gear to road speed, you can move rpms up or down faster than road speed. If your doing say 30 in 5th and you go for the change, get nutrual but cant find the right rpm for 6, after about 4 or 5 seconds your going to slow, but you can keep your rpms right..... but it still aint gonna want to go. Just go back to 5 and try again. (Your speed/gear ratio may vary) :)
