Floating revisted
Discussion in 'Questions From New Drivers' started by GiantBeard, May 12, 2016.
  1. GiantBeard
    GiantBeard Medium Load Member
    323
    343
    Oct 16, 2015
    Petaluma/Indio, CA
    A few months back I had questions about how to shift. Double clutching and floating. Upshifting, and downshifting.
    Now that I've been on the road for about 6 months, I'm feeling a lot more comfortable with both methods, but since I haven't got anyone to 'compare notes' with, I just wanted to see if what I think is right, sounds right too.
    Double clutching seems easy. Just let off the throttle, pop it once, hit neutral, pop it again, ease it into gear.
    Floating seems like the finer art here though. I used to think that I had to take my foot off the pedal during all shifts. Lot of lurching, unhealthy, and generally unpleasant motions from that.
    It took me a while to understand that the throttle should never be let off 100%, that I should always have just a tiny bit of throttle, and the gear just slides in, when upshifting.
    Downshifting, heck, I've come to know my transmission to the point where I can just hold the RPMs in neutral and slide it right it. I just give a little tap on the throttle, pop into neutral, pick the appropriate RPM, shift, and then let off the throttle to slow down. I used to put my RPMs way too high, feeling for the right spot until it fell into place.
    I know manual transmissions are going out of style, but as long as they aren't illegal, I'd rather have the closer connection with my vehicle. So tell me if this sounds like I'm still ####ting the bed or if I may be on the right path to success here.
  3. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    Yup - you're doing good.,
    Doesn't need to be all the way off the throttle to release it out of gear - just enough release of torque/pressure to slide out . . .
    If you've got the downshift mastered, you're 90% there.
    Lepton1 and GiantBeard Thank this.
  4. Kyle G.
    Kyle G. Road Train Member
    3,850
    20,210
    Jan 23, 2016
    Eastern Iowa
    This is why I miss driving a manual. That feeling of "being one with the truck..." Getting to know its sweet spots and how to find them without really trying... Isn't it great?. Now I have to work on "being one with the truck's computer," which is just not the same.
  5. PO Stoner
    PO Stoner Light Load Member
    132
    67
    Jul 6, 2015
    I plan on never going back to an automatic. How many times does your computer lock up and you get the blue screen of death? It happened to me with an automatic. The computer fell asleep at the wheel and didn't down shift on an exit ramp. Of course, that was 13 years ago when automatics were new. Maybe they're better now. Maybe I'm a control enthusiast.
  6. Trubb43
    Trubb43 Light Load Member
    185
    67
    Mar 16, 2014
    When I was taught always was told pressure on the stick even when I double clutch it Makes it so much easier
  7. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    When I spent my stint as a trainer at Swift I had my trainees, who normally got in my truck with an average of 10 hours behind the wheel from school, start floating on the 2nd or 3rd day. Part of my strategy was to get them OVER the two big issues with shifting.
    First, there's the Happy Feet Syndrome. Needing to floor it or get completely off the throttle. Part of this transition would be having them park it, set the brakes, and practice taking it from 1100 rpm's to 1500 rpm's to discover how LITTLE they have to move the throttle. Just a fraction of an inch.
    The second tendency to overcome was the Mohammed Ali Jab. They get out of gear, hover in neutral, romp on the accelerator and then let it off completely, THEN JAB at the gear... hoping that they time it for the split second that the rpm's will be perfect.
    It never failed. When I did the 1100 to 1500 rpm drill, then had them float from 2nd from highest to highest to highest gear simply by pulling on the gear shift and dropping from 1500 to 1100... they always got that excited look in their eyes. They just shifted a gear without grinding! It went in like a hot knife through butter!
    Everyone should learn to float AND to double clutch. Floating teaches you the finer points of throttle control and double clutch helps you get there faster.
    Bob Dobalina and blairandgretchen Thank this.
  8. MM3Deg
    MM3Deg Medium Load Member
    354
    159
    Sep 23, 2007
    Fort Worth, TX
    1000 and 1500 wad drilled into my head for three weeks....
    And I thought I was crazy for struggling so much with shifting.
    Once I got my own truck and played with it a bit I figured out that 1250 and 1750 were the sweet spots.
    Of course I am sure this may vary among truck... You have to experiment, and find the sweet spots.
    Learning to 'feather ' the throttle is also a good point!
  9. Bob Dobalina
    Bob Dobalina Road Train Member
    2,578
    4,456
    Sep 20, 2015
    The "Buckeye"
    Also, start paying attention to the amount of RPM difference between every gear. My truck, for instance, has a 300 difference between all the gears until the top 2 shifts, where there's a 400 RPM difference from 8 to 9 and 9 to 10. So for those last two shifts the "wait" is slightly longer.
  10. realdesertkickin
    realdesertkickin Heavy Load Member
    925
    752
    Nov 18, 2013
    Tustoned Arizona
    Ya dont need rpm gauge....thats for begginer to have somewhere to start..
    Your progressing just fine...If you drove 5 trucks all exaclty the same as yours, they'd all be a tad different...
    Start skipping gears up and down, you'll really become one with your tranny
    Double clutching is funny...I call it 'stompin spiders"....
  11. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Sweet spots vary between motor types of the same brand.
    I've driven a MBN CAT C-15 (single turbo) for the past three months. I've also driven a ST 6NZ C-15, TT C-15 (can't remember the model) and a TT C-13 (again, no model). All four have had 13 speed Eaton Fuller manuals.
    The sweet spot for the MBN is between 1150 and 1350. The 6NZ is 1200-1400. The twin-turbos were both about 1300-1500. I also drove a 425 Paccar with an 18 for several months, and it was 1400-1600.
    It's almost crazy how much the torque curve can vary from truck to truck, let alone between engine types (CAT, Cummins, Detroit, etc). Plus there is things like Cummins have a much faster "drop" than CAT's do, among other things.
    It all comes down to getting in a single truck, and "feeling it out". Slip-seating manuals is a quick way to ruin a driver's pride. If they're new to it, they'll never get it right.
    As for the TC, I've been in this for just over a year now, and it took me about as long as you to really start to understand floating (which my company wants). Now I can shift smoother than the Pete 579/KW T-680's that we have with automated manuals that think maxing out the RPM's, then slamming it down into the next gear whether loaded or unloaded, partial throttle or full throttle is the best way to do it.
    I can't see how using the clutch to shift the gears really saves all that much on transmission wear like Eaton claims. Granted, learning to float sure probably puts a whole lot more wear on the transmission, but that's what older trucks with too many miles are for.
    Dr.Lou Thanks this.
