Freezing! Need help with APU
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by ZhenyaP1991, Jan 12, 2016.
  1. ZhenyaP1991
    ZhenyaP1991 Medium Load Member
    573
    702
    Nov 6, 2014
    I have Thermo King APU evolution, with three knobs for control. it worked fine when I stopped. Now I realized I can't control it at all. LED lights are stuck and they won't turn off, therefore my APU won't kick in. I completely turned the power off to the truck, but that didn't do nothing. So, I am sitting here, trying drain APU battery. Any help would be awesome
  3. lady doe
    lady doe Light Load Member
    72
    4
    May 25, 2014
    I FEEL YOUR PAIN! I HAVE THE APU, BUT ITS THE OLD STYLE. WHEN I TURN IT ON IT WONT DO ANYTHING BUT JUST SPIN NO CODE COME UP AT ALL. ITS LIKE ITS NOT GETTING ENOUGH OF FUEL OR PRIME LOST IN IT I JUST DONT KNOW. THERMO KING WILL CHARGE U TWO ARMS AND A LEG. ANYONE GOT ANY IDEA WHAT MAY BE GOING ON WITH IT.
  4. MM71
    MM71 Heavy Load Member
    760
    991
    Jun 28, 2008
    AZ
    http://www.na.thermoking.com/conten...Pac EVOLUTION 55711-19-OP (Rev. 1, 03-14).pdf
    That is the manual for your apu. If you cannot trouble shoot it. Call the number provided on one of the last pages.
    Why would you drain the apu battery? The heater is an espar under the bunk, nothing to do with the apu running other than providing juice for the heater fan. Do you want to power the truck and apu off by unhooking batteries? Its easier to just pull fuses.
  5. reefer101
    reefer101 Medium Load Member
    444
    246
    Oct 24, 2014
    bunk heater will not drain the batteryes if they are good. just turn off your fridge and tv
  6. ZhenyaP1991
    573
    702
    Nov 6, 2014
    It won't run the heater, since the control knob doesn't turn off. It's like you know when your computer freezes, that's what I am dealing with right now.
  7. CJndaTruck
    CJndaTruck Road Train Member
    3,349
    3,365
    Nov 21, 2014
    Knoxville, TN (area)
    The knob is a button also. Left knob that is.
  8. MM71
    760
    991
    Jun 28, 2008
    AZ
    Pull fuses and replace fuses. If that does not work. Call number ... Thermoking emergency "cold" line (888) 887-2202
    or idle. or if not allowed to idle call company and get a hotel room. or bundle up.
    Good luck!
  9. ZhenyaP1991
    573
    702
    Nov 6, 2014
    No worries everyone, I got it fixed. This is a newer model of Apus and it has a motherboard sort of. So, like I said it's like a computer. Unplug it and plug it back in. The correct term of 3 knobs is HMI controller, if I knew that from beginning, I'd be sleeping already
  10. lady doe
    72
    4
    May 25, 2014
    THE COMPUTER PROBLEM; FLIP IT OVER AND TAKE THE MAIN BATTERY OUT AND COUNT TO 10, THIS SHOULD ALLOW IT TO RESET ITSELF, PLEASE LET ME KNOW IF THIS HELP , LADY DOE
  11. supersnackbar
    19,824
    50,988
    Aug 19, 2007
    Your Town, USA
    My APU Evolution starts within a few minutes of starting my airtronic bunk heater and cycles on and off every 30 minutes or so. And this is a brand new truck with 15k miles.
    americanmadetrucker Thanks this.
