Hi I’m Having a problem with my air system while parked it will build up like it’s supposed to but while driving it will not go above 110.any help will be greatly appreciated
Freight liner not building enough air while driving
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dunkin1122, Jan 16, 2021.
Spring brake leaking?
Does it do it when parked with the brake buttons pushed in?magoo68 and BoxCarKidd Thank this. -
baha Thanks this.
Tires have auto inflators? Bad tire someplace.
Flat Earth Trucker Thanks this. -
Considering we have no clue what truck all I can say is air leak.
110 isn't high enough?
Don't dryers have a adjustment? -
You shouldn't be driving it with a leak that bad. Park and get it fixed. Air leaks don't fix themselves, they only get worse. The last thing you want to happen is to be driving and having both your red and yellow buttons pop out...
Definitely sounds like a bad maxi canOldeSkool Thanks this. -
Of course block the wheels before you do this so the truck doesn’t roll over you or away.
