Freightliner Cascadia 2023 SCR Issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by EddySmith, Sep 28, 2025.
  1. EddySmith
    EddySmith Bobtail Member
    7
    Hello there good people
    I have Freightliner Cascadia 2023 with DD15 and truck went into Stage 2 - Torque Derate for some reason
    5 minutes after, on the dashboard i found couple of fault codes related to DEF System. DEF Level was just a bit below the maximum.
    Went at the closest Speedco and they did SCR Test and Forced Regen, and unit passed SCR Test. Forced Regen was also sucessful but codes won't go away. And they can't delete the codes ( Picture of codes attached ).
    What it could be ?
  3. 062
    062 Road Train Member
    6,264
    33,741
    Oct 20, 2013
    I would recommend finding a shop that uses diagnostic link 8 or a dealer. Once the root cause is fixed it will need scr efficiency tests performed to bring the nh3 level up to a 1.
    KDHCryo Thanks this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,743
    9,103
    Jul 12, 2017
    Not a Detroit guy but it looks like you probably have an outlet Nox driving the DEF dosing rate to max. As stated you may need OEM software to disable derate.
    Diesel Dave Thanks this.
  5. EddySmith
    7
    Thank you guys.
    Truck is still at the dealership, i'm waiting for their answer on the situation.
    Do you think these codes could have something in common with codes for injector ?
    I had couple of fault codes recently for Injector No.6 - Electrical issue.
  6. EddySmith
    7
    Dealership said it's cause of Rear Injector harness.
    He will replace it.
    Don't know yet how Injector wiring is connected to DEF Issues ?
  7. JB7
    JB7 Heavy Load Member
    946
    1,624
    Dec 13, 2022
    Laurel, MD
    Are they talking about the engine injector harness or the DEF doser harness?
    For the first 2 codes there is a service bulletin.
    0808-18.pdf
    For the 4th code 520372-16
    SPN 520372 FMI 16 | TruckersReport.com Trucking Forum | #1 CDL Truck Driver Message Board
    They should also check for cracks/leaks in the aftertreatment system.
    Everything upstream of the aftertreatment needs to be operating correctly and any problems corrected before going into the aftertreatment.
  8. EddySmith
    7
    I thought also they're talking about DEF Doser harness but i recalled i had couple of weeks ago codes on dashboard for Injector 6 Open circuit
    So i called again just to double check and they said it's Fuel Injector harness which is causing the trouble
  9. EddySmith
    7
    Lol..Now they found out whenever Jake Brake is on, regen process kicks in
    How these two are actually connected lol..
  10. KDHCryo
    KDHCryo Medium Load Member
    551
    798
    Sep 14, 2023
    The reason it went to derate is beacuse you idle it all the time.
    Drive it for 300 miles and it will burn the soot off the SCR face, while doing road regens. Don't stop at every Loves and let it idle in the fuel island.
    Quit going to Speedco, go to a dealer and they will tell you this.
  11. KDHCryo
    551
    798
    Sep 14, 2023
    That is absolutely false...Speedco said that because they wanted you to get out of there shop.
    You can't start a regen if the Jake Brake is engaged per DDDL8 software.
