Frieghtliner cascadia dpf get hot
Discussion in 'Ask An Owner Operator' started by khan1122, May 11, 2017.
  1. khan1122
    khan1122 Light Load Member
    68
    31
    Jun 10, 2015
    Hello all
    I have 2014 fright liner cascadia
    Right side of the truck where the after treatment system is located gets hot while I drive
    Is it normal ?
    Please help
    Thank you
  3. Brandt
    Brandt Road Train Member
    4,514
    6,179
    Sep 17, 2012
    I would guess it normal. I never heard anyone said it gets hot but the DPF is cleaning it's self going down the road couple times a day. I'm not sure how hot the active Regen are. The normal parked regeneration will run the DPF up to about 900-1000 F. So how hot it normally is driving I'm not sure but it probably pretty hot. It's getting hot enough to burn the soot/carbon build up.
    khan1122 Thanks this.
  4. khan1122
    68
    31
    Jun 10, 2015
  5. khan1122
    68
    31
    Jun 10, 2015
    Thanks for the reply really appreciate it
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    Yup. I have my scangauge set to read DPF temps amount other things. Going down the highway in the summer fully loaded it will run over 700 degrees all day long and at times over 1000 degrees when doing a regen. Runs about 580 degrees in the winter.
    If it was actually doing a regen when you come off the highway you may see the high exhaust temp yellow light on your dash. It's just to warn you in case you planned on touching it when you stopped.
    ChicagoJohn, khan1122 and Brandt Thank this.
  7. mitmaks
    mitmaks Road Train Member
    2,560
    2,075
    May 16, 2014
    If theres yellow warning light when you pull off highway and oark somewhere its most likely doing a regen, so let it finish by setting brakes and pressing/holding manual regen button for several seconds. If it requires it, engine rpm will rise and finish parked regen.
  8. khan1122
    68
    31
    Jun 10, 2015
    No it don't have the yellow light driving normal but when I stop the right side step get hot as well
  9. mitmaks
    2,560
    2,075
    May 16, 2014
    Its normal as DPF has to get hot enough to burn soot inside.
