Front safety pins unlock
Discussion in 'Intermodal Trucking Forum' started by w.h.o, Aug 19, 2014.
  1. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Okay guys you know the front pins you push in and lock in so it wont slide off the chassis? Well some driver decide not to push it in and the box shifted while gettin loaded. So my question is how to get it in and secure without unloadin the whole trailer. Never had this problem until now and wondering what you guys do
  3. Cody1984
    Cody1984 Medium Load Member
    419
    249
    Jan 24, 2014
    PA
    Are the pins out of alignment vertically or horizontally. If they are out of alignment vertically as in the pins need to be moved up to be able to slide them in then you can attempt back your fifth wheel under each edge of the chassis to jack up that side so you push that pin in. You would do that for both sides. If a jockey is there their wagon is perferrable for this since he/she can raise and lower the fifth wheel.
    If the pins are out of alignment horizontally then you can attempt to get them in alignment by rubbing your container against another container (preferrably loaded container) to try and shift the container back into alignment with the pins. If you don't feel safe doing either method call your company up and tell them what happened with the container... You should call them up either way actually since one pin not pushed in is bad but forgivable if it can be fixed by jacking up the end of the chassis if it's horizontal I would report that driver for sure but two is pathetic and the driver who did that needs to get reported.
    w.h.o Thanks this.
  4. w.h.o
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Thanks, its off horizontally but this info is new to me never thought of that
  5. Cody1984
    419
    249
    Jan 24, 2014
    PA
    Yeah horizontally outside of rubbing it against another container which as we all know is considered an incident and frowned upon by most companies is the only way you can attempt to fix it without outside help.
  6. timdriver81
    timdriver81 Light Load Member
    85
    65
    May 7, 2014
    Horizontally. Learned a trick that works most of the time, unhook from the chassis and back to the kingpin slightly off center so the kingpin hits the inside of the fifth wheel and causes the the chassis to slide left or right and can also align the pins to the box if its not to far off. Also make sure the landing gear is down tight because the chassis needs to flex against resistance not just twist the tires a lil. Can't really explain it but do you see what I'm saying?
    Cody1984 and w.h.o Thank this.
  7. Cody1984
    419
    249
    Jan 24, 2014
    PA
    Basically use the weight of the container combined with the force of the tractor via the fifth wheel pressing against kingpin at an angle to slide the chassis into alignment...correct?
  8. timdriver81
    85
    65
    May 7, 2014
    Ya, correct. It doesn't sound like it would work but try it sometime lol.
  9. 201
    201 Road Train Member
    12,089
    24,684
    Apr 16, 2014
    high plains colorado
    Something doesn't sound right. There is kind of a notch in the bottom of the container the chassis fits into. The box shouldn't slide off the chassis even if the pins aren't pushed in. It doesn't sound like the box is on the chassis right. The pins only secure the box from jumping out of the notch.
  10. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Driving around the yard with a few turns might put the box back in it's place.
    Shame you didn't post any pics,it would have made solving this much easier
  11. 201
    12,089
    24,684
    Apr 16, 2014
    View attachment 70601 That notch in the middle of the box is where the chassis rides. It really can't slide off the chassis.
