Fuel is not traveling between tanks
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JohnSmith69, Nov 16, 2020.
  1. JohnSmith69
    JohnSmith69 Light Load Member
    64
    29
    Feb 23, 2020
    One day I was driving down the highway at 65 MPH weight 80k lbs and my truck turned off on me. Turns out fuel is not traveling between tanks and I had run out of fuel on the passenger side. The passenger side tank is being used 80 percent more than the driver side.
    Took it to a mechanic and he said there's a valve that's between the tanks which is probably bad. Then he changed his mind and said it was just debri and the valve was fine. Then it happened again. Then he's trying to tell me it'll take 10 hours of diagnosis to fix because he has to put a camera inside to see where the problem is (which would cost me over $1000). To me it sounds like he's just trying to make money. Should I just change the valve? Any advice is appreciated
  3. Lyle H
    Lyle H Road Train Member
    1,291
    2,937
    Apr 16, 2014
    Your tank vents could be plugged.
    Or a cracked pickup tube.
    Or something blocking the pickup tube.
    Splitter valve could be plugged.
    Loosen a fuel cap and listen for pressure buildup.
    Do the tanks equalize after sitting for a while?
  4. blairandgretchen
    13,426
    72,379
    Dec 9, 2011
    South west Missouri
    Vents in caps - shut off valve in crossover line.
    $1,000?
    Bring it to me and we’ll figure it out over a 30 pack.
  5. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    Year, make and model would be helpful
  6. pavrom
    pavrom Road Train Member
    3,186
    7,309
    Apr 29, 2012
    NE illinois
    Disconnect driver side lines from splitter and blow them with the air gun . Fixed it for me , since February . Exactly the same ...i checked breathers and splitter first
  7. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Put one of these in your tool box
    JohnSmith69 and LtlAnonymous Thank this.
  8. b61mack
    b61mack Light Load Member
    60
    70
    May 18, 2010
    port murray nj
    As a temporary fix open fuel cap slightly this will break the vacuum. Fuel should equalize the tanks
    JohnSmith69 Thanks this.
  9. AModelCat
    160,686
    Run from that guy. He's trying to hose you IMO.
  10. flood
    flood Road Train Member
    4,163
    4,035
    Dec 25, 2010
    It's 1 of 2 things
    #1 The vent tube is blocked on the drivers side.... to check fell the drivers side full and passanger side 1/2 or less, park the truck turn the truck off and crack both caps a little. Check the level about 1hr later, they should be the same... if so take off the vent tube and blow it out or replace it.. if not #2
    #2 you have a blocked fuel pickup or block fuel line. To check disconnect THAT fuel line as far away fron the fuel tank as posable and blow it out until air is blowing into the tank. 2 or 3 times then hook it back up and see it they equalize.. if so that was your problem.... now if #2 fixed it you need to check your tank... (you can get a cheap endoscope "bore scope") for under $100. You need to see if there is any junk in your tank...... an old way to F someone you didn't like is to throw a pice of plastic bag in someone tank... it will float around forever until it gets sucked into the fuel line. If you just blow it out it will do it again...
  11. God prefers Diesels
    4,198
    22,261
    Jun 26, 2020
    South Texas
    You could probably replace both tanks, and everything in between them for that much money. Jesus.
