Fuel your truck while running
Discussion in 'Experienced Truckers' Advice' started by scatruck, May 16, 2011.
  1. scatruck
    scatruck Light Load Member
    89
    37
    May 23, 2007
    Bonham TX
    I was at a different trucking forum and the following question was asked and I think it's an excellent question ( thanks to General Lee for the question)
    Do you fuel your big truck while its running? Do you fuel your personal vehicle while its running?
    If you do then why? If you don't then why?
    Just curious on the particulars here because I was having a discussion with a friend on why this is or isn't dangerous.
  3. Pa geargrinder
    Pa geargrinder Light Load Member
    58
    12
    Aug 1, 2010
    Pa
    No shut them all off at present!
    Due to the price of fuel ,even motorcycle..
    Usually leave it run fuel and go!
    Most fuel fire are started from a Spark or a flame !
    Gasoline can fire off rather quickly , Diesel not so quick.
    Pretty much personal preference , but we have all heard the Claims and the danger stories ! lol
    Pa.
  4. Svoray
    Svoray Medium Load Member
    558
    194
    Feb 3, 2011
    Texas
    Gasoline refueled while shut off
    Diesel refueled while running.
    As for why, who knows, I will say my job is refueling semi-tractors and huge V12 diesels in the field and these for the most part are all done running. The only time they shut them off is when the company man calls it a day or the job is done.
  5. Jon
    Jon Bobtail Member
    23
    13
    May 14, 2011
    Winter Haven FL
    I always shut the truck OFF. Why? So I could check the oil at the same time.
  6. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    I shut the truck off, but I idle it down for a couple minutes before I actually turn it off.
  7. formertaxidriver
    formertaxidriver Heavy Load Member
    767
    375
    Jan 22, 2008
    Aiea, HI
    Flammable or explosive hazmat? You MUST turn the truck off.
    I have a five minute idle engine cutoff (that can be overridden with the cruse control) that I let run out to make sure my turbo has cooled off from highway temp. That usually is the time it takes to get the pump turned on. So I guess off for me.
    Rollover the Original Thanks this.
  8. scottied67
    scottied67 Road Train Member
    10,816
    12,615
    Mar 14, 2010
    california norte
    In my personal gasoline powered pickup I usually just left it running while refueling. Wintertime when it was cold out, I could get the pump started and hop back in with the heat on. Summertime, same thing but with A/C on. Never had a problem.
    Big truck out here, hop out while it is running to swipe cards and start the pumps. Left it running only a couple times as an experiment (also to cool down the engine from after running for hours, or to keep it in the warm-up if I'm fueling first thing to start the day) to see if it would bring up some kind of log violation. No problems yet, may continue.
  9. good for nuthin'
    good for nuthin' Light Load Member
    87
    51
    Dec 8, 2010
    Las Vegas NV
    The only time I have left either vehicle running while fueling is due to the fact that the battery got drained and if I stop the motor, it will stay stopped.
  10. American-Trucker
    American-Trucker Road Train Member
    10,371
    5,085
    Nov 8, 2009
    Charlotte, North Carolina
    all gas vehicals should be shut off, if you leave it running your going to end up blowing yourself up, your fuel pump and sending unit as well as the gas going into the tank cause static.
    I'm a A&P Licensed Aircraft Mechanic and a Auto Mechanic, trust me! lol
    As for diesels do what you want, I leave my F-250 running just because I dont want to keep cranking it up starters arnt exactly cheap, and usually by the time my EGT's come down to shut it off i'm all ready full.
    As for my big truck i shut it off, only because its really loud and i dont wanna hear that crap haha Its loud enough while driving (freight shaker)
    American Trucker
    Wiseguywireless Thanks this.
  11. NDBADLANDS
    NDBADLANDS Medium Load Member
    698
    323
    May 8, 2010
    ND
    You don't shut a hot truck off. We run 24 hrs during harvest, we fueled with truck running. Now, if you can cool it down, let it idle for 10 minutes or so, then we would shut it off. Only what i have been told and taught.....don't rip me on this. Thanks in advance.
    scottied67 Thanks this.
