Gear Ratio Confusion
Discussion in 'Ask An Owner Operator' started by PO Stoner, Mar 19, 2016.
  1. PO Stoner
    PO Stoner Light Load Member
    132
    67
    Jul 6, 2015
    After searching info on gear ratios, I'm still confused on which way to go. I currently drive a Cascadia with a DD13 and 3:70 gears. It is an absolute dog of a truck. If there is a stiff breeze, it won't maintain 70 on flat terrain. I'm considering going O/O intermodal and will need to buy a used truck. I'd like an old school Series 60 Columbia without all the DEF stuff since I will never go to California. I used to to drive a Series 60 Columbia and loved it except for the cab noise. I want to do at least 75mph, maybe 80, if needed and not suck down fuel. Penske likes 3:70 gears. Ryder trucks seem to favor 3:54 gears and the used Schnieder trucks seem to all have 2:64 gears. I lean towards 3:54 gears at 455hp. I think that would make a decent 75mph truck. All the trucks I'm looking at are at 455hp (a DD13 is at 400). So, what gear ratio gives you speed, can still reasonably pull hills and not suck down fuel as bad? Most of the trucks I'm looking at are 10 speeds. I'd consider a 13 speed if I ran across one. I'm assuming most containers are pretty heavy. I'm usually around 70K now so I know the DD13 is useless if I were to consider a CARB truck. A DD15 would be okay I think, but again which rear end?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Well it will be hard to get fuel economy at those kind of speeds.
    I have a DD15 and it seems to like to run a little higher rpm than what the mfg says. It pulls better above 1,450 rpm and kind of seems to fall off by 1,700 rpm.
    What tire size you run?
    Assuming 11R22.5, 3.55 rears would run about 1,600 rpm at 75 mph or 1,700 rpm at 80 mph.
    For a DD13 that might be about right to have any kind of performance. For fuel economy you'd want to be under 1,500 rpm, so say a 3.36 rear but it would be a real dog.
    I had a 450 Mercedes with 3.58 and it had no guts at all. I changed them to 4.11 and it pulled way better and gained almost a full mpg, but I only ran it at 62 mph.
    blairandgretchen Thanks this.
  4. blairandgretchen
    13,302
    71,125
    Dec 9, 2011
    South west Missouri
    4.10 should pull a small elephant up the side of building.
    2.64 will give you the speed you want, but you'd want a 13 or 18 for the hills - I imagine a 10 you'd be forever shifting 9/10.
    Follow @Cowpie1 - he went 2.64/13 or 18. I picked his brain a while back on this subject.
    3.55/13 with my N14 gives 1500rpm@ 69mph. Gets 7 mpg.
  5. 201
    201 Road Train Member
    12,148
    24,798
    Apr 16, 2014
    high plains colorado
    I drove a '99 Frightliner Columbia with a 500 Detroit, 13, and 3:55's, and that was a good combination, I thought. 7mpg, all day and 70 mph was like 1550r's. While I didn't care for the truck all that much, ( it did ride nice) if I got another truck, ( did Hell freeze over yet?) it would have that setup.
    x1Heavy Thanks this.
  6. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    2.64 with 10 speed direct & 22.5 LP:
    1300-1700 rpm
    6th: 18-23mph
    7th: 24-31mph
    8th: 32-42mph
    9th: 44-57mph
    10th: 59-77mph
    2.64 with 13 speed double-over & 22.5 LP:
    8th: 36-48
    9th: 43-56
    10th: 50-66
    11th: 59-77
    12th: 68-90
    13th: 81-105
    3.55 with 13 speed DO & 22.5lp:
    8th 27-35
    9th 32-42
    10th 37-49
    11th 44-57
    12th 51-67
    13th 60-78
    3.36 with 13 speed DO & 22.5lp:
    8th 29-37
    9th 34-44
    10th 40-52
    11th 46-61
    12th 54-70
    13th 63-83
    11R22.5 & 24.5LP is ~4% faster
    11R24.5 is ~8% faster
    TallJoe, Terry270, PO Stoner and 2 others Thank this.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    The DD series is probably about the best out there today but it still doesn't feel like a pre egr ddec3 did. In our dd15 455 I would have volvo d11's and old R model mack's out gun me on the hills. We also had de-tuned ryder trucks so I have no idea if they were actually 455 or not. My dad swears up and down his previous 460 e7 would walk a new dd
  8. PO Stoner
    132
    67
    Jul 6, 2015
    All good stuff. Thanks dudes. 3:70 gears are out. Why is it Schneider tends to be the only big company running 2:64 gears? I guess that would be huge for fuel savings at 65mph but you'd be shifting constantly on every hill. With speed you'd get a good run on the hills so maybe it wouldn't matter at say 75. I'm thinking for intermodal with lots of city driving, the 3:54 gears might be better. Sort of the in the middle option although 75 will be it. Any faster and the engine rpms will be too high and I'll burn through fuel in a major way. Currently I haul cars with a DD13 and usually get 4.3mpg, but that's hauling cars (lots of drag) so anything will exceed my expectations.
  9. 201
    12,148
    24,798
    Apr 16, 2014
    From my experience, Schneider usually hauls light loads ( out of Green Bay, anyway) toilet paper, diapers, paper towels, and I think it was their way to drop the rpms for fuel mileage, and those trucks don't downshift much and they are governed at 62, I'm sure. That 2:64 ratio is a bit odd, not many others use that ( I don't think) Like I say, I'd go with mid 3's and a big motor. Years ago, with no hp, you had to wind the piss out of those motors, and 4:11, even 4:30 gears were normal.
    The_Great_Corn Thanks this.
  10. Misesian
    Misesian Road Train Member
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    My truck is a 2.64 with direct 10. I don't constantly shift or have issues with power. I get a light load once in a while but usually gross 72k or higher. This puts my cruise speed at 60 mph. If you want a faster truck than that you need a faster rear or an OD Trans with a more conventional rear. You can find calculators online to do the work for you then work on finding the truck that matches your needs. Rears themselves don't determine pulling power; they determine the RPM at a particular road speed and that determines the HP you will be putting out or "pulling power."
  11. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    They're not the only one, they were just one of the first. Lots of new fleet trucks run 2.50's now, and there are even lower options.
    When paired with a 10 speed direct, 2.64's are a good fuel mileage gear for the 12.7 running ~62. It'll comfortably run 57-68, with 2.79's being better for 55mph and 2.50 being better for 70+
    You probably won't find an unmodified truck with a 13 speed and that type of gearing though, and if you wanted to go custom there is always the 13 speed direct and the 13 speed single over-drive. The main downside is that these transmissions are not rated to handle as much torque as the standard 13 double-over.
    77fib77 and PO Stoner Thank this.
