It’s been explained. The stress of the side loading is not good for the pinion. The heavy weights with low rpms is not good for the u joints. I doubt you can get this set up in anything other than 40k rears if you can even get them in that. Start ability will be an issue, but may not be a problem in your operation. Grade ability will be a big problem. Everyone want to quote how well and compare pulling in top gear. Climbing a hill you will be farther into the gear box trying to make the top of a hill. If it is a long enough/steep enough grade you will run out of gears. Then what? The fuel you save on the level you will loose in the hills. You will be working the engine much harder this burning more fuel. At a certain point your gearing gets so high, economy starts going the other way
Gear ratio over drive or direct for heavy haul up to 110K?
Discussion in 'Heavy Haul Trucking Forum' started by Nick34, Jan 12, 2019.
Page 5 of 10
MagnumaMoose, Tombstone69, Dino soar and 4 others Thank this.
MagnumaMoose, cke, SAR and 2 others Thank this.
Go back and read post #21. That 2.64 will have a lot of torque on it starting. That's why people are saying you'll be broke down all the time, shearing the pinion shaft. I think a 3.55 or lower gear would be quite a bit stronger. Will Freightliner even spec a heavy haul truck with the 2.64?
MagnumaMoose, cke, wore out and 2 others Thank this. -
100,000 miles doing heavy haul? Let me hold a dollar...
Arkansas Thanks this. -
If you have a direct drive trans and a higher gear rear, your top speed RPM will be near the same as if you went with a OD trans and lower gear rear. The final ratio is near the same, so I really don’t understand the difference.
I know who KR is, but I’ve never really listened to him. If you are getting your info from him, you need to stop. Think about it, if he knows all these ways to get rich in trucking, he’d own a trucking company intead of just talking about all the ways other people are doing it wrong. It’s my understanding that most of the stuff he pushes is just whatever his sponsors tell him to push.TripleSix, cke, Heavy Hammer and 3 others Thank this. -
If you tighten 1 bolt it don't matter much but if you do 100 a day you will be a lot more tired at the end of the day.
The same thing with a truck yes you may do the same work but if you work it harder you put more strain on all components instead of lighter work but a little more movement.
The strain will show on every component from the fan to the tire contact patch.MagnumaMoose, Dino soar, cke and 5 others Thank this. -
I do agree with that statement but think about we do have a taller gear in the rear end so yes that would be harder to turn but a lower gear in the transmission 1 to 1 instead of .73 to 1 like an overdrive would it not equal it self out because we are doing most of our gear reduction in the transmission? I could see the argument maybe we would be putting a little more stress on the drive shaft itself
Page 5 of 10
