Getting a new clutch brake couple questions
Discussion in 'Questions From New Drivers' started by Zacgehret, Jun 29, 2018.
  1. Zacgehret
    Zacgehret Light Load Member
    67
    54
    Jun 21, 2018
    Kilbourne il
    Getting a new clutch brake cuz this one didn't work when I picked it up so question I do they have to put a new clutch in or is that up to them and if not will they still have to ajust the clutch cuz I asked the boss to ajust my clutch when I picked this thing up boss tells mechanic mechanic says ok boss leaves I turn around mechanic is gone 3 hours later I say f it and leave so will he have to adjust it with the work or do I need to wait till they open Monday and throw my was in the air
  3. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    Having no clutch brake is a pain if you do not keep it in a gear, just select the gear you need before stopping, roll up on stops slower so sometimes the light changes and you do not have to stop. Any trouble getting it in gear when not rolling might have to stop engine. Bad clutch will make a bad transmission in time and those much more expensive than clutch, throw out bearing and the labor.
    Zacgehret and Dino soar Thank this.
  4. supersnackbar
    19,232
    47,774
    Aug 19, 2007
    Your Town, USA
    Unless you have an auto-adjusting clutch, they will have to adjust it. To get to the clutch brake, unless things have changed, they have to pull the trans and clutch to get to it, so they may as well put a new clutch in it while it's out.
    Zacgehret Thanks this.
  5. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    Depends, but normally you can cut the old single piece brake out with a torch and then put a two piece brake back in.
  6. Mack185
    Mack185 Medium Load Member
    448
    262
    Feb 25, 2008
    Yup, that's the only way to do it that makes sense. I've seen bad drivers tear up a clutch brake quicker than hell, stop pushing the clutch to the floor when the trucks still rolling drivers!
    Samuelh and dibstr Thank this.
  7. dibstr
    1,308
    932
    Sep 10, 2010
    I’ve always wondered why they don’t put two piece brakes in from the factory, especially considering all those who just will not (as you said) stop pushing the clutch to the floor when the trucks still rolling.
  8. Dave_in_AZ
    389,736
    Bad habit formed during training. Go fast not right.
  9. MACK E-6
    49,038
    227,820
    I had mine tweaked a while back that didn’t require any of that, thankfully.
  10. Zacgehret
    67
    54
    Jun 21, 2018
    Kilbourne il
    So there is a chance I could do the work and still not ajust the clutch and just so people know it didn't work when I got the truck I learned to drive with a farmer that did his own repairs so dos and don'ts of the clutch were stressed over and over and over and over and over
  11. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,293
    Sep 12, 2017
    Plymouth MI
    If a one piece clutch brake, just cut it out with a torch. Install a two piece HD unit, it snaps right in, nothing has to be removed other than say an inspection plate to do the job. The clutch adjustment, if a manual adjust, takes two people to do it right. Auto adjust, that is another animal and not much one can do with those, at least the ones I am familiar with. I am not a mechanic.
