Going out to get own Authority. I hear that alot of Brokers wont use you for 3 months
Discussion in 'Ask An Owner Operator' started by Big Lou, Oct 9, 2014.
  1. Big Lou
    Big Lou Light Load Member
    155
    25
    Aug 15, 2013
    Tampa, Florida
    I am working under someone else Authority right now been doing it for years. Over the years picked up some direct clients so deciding to go out on my own Authority. I was checking around and found out a lot of Brokers wont use you with new Authority for like 3 months they want some background on you also some information on Safety and DOT. Ex like when you get pulled into a scale and they do a full inspection and report it to the DOT. Does anyone no what brokers use new Owner Operators??
  3. orangepicker
    orangepicker Road Train Member
    1,159
    679
    Nov 9, 2011
    florida
  4. Gentlemanfarmer
    Gentlemanfarmer Medium Load Member
    365
    384
    Feb 26, 2010
    Greenville, FL
    When we first got our authority we had to use bottom feeders like TQL, CH Robinson and such. We only encountered a few that required six months to a year. Funny thing is that those who made us wait don't seem to be around today. Get your own authority and you will be fine. Use load boards like Getloaded and Truckers Edge that will show you a broker's credit rating. I recommend using a factoring company like TBS Factoring for quick oay if the broker doesn't offer the service.
  5. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    You'll be fine.
    If you provide a reliable service, your reputation will carry you and as soon as you post your truck as available, those that know you will call. Those that want to know you will call also.
    Just dont get labeled for hauling cheap. Its a double edged sword. You need to run,.. but need to make money. If you know what your bottom line is to haul a load,.. dont go below that.
    Hurst
  6. xsetra
    xsetra Road Train Member
    5,119
    6,998
    Aug 21, 2011
    Everyone company hauling started at the same spot. You should be no different. Lot of work available. Jump in and have a good time. Good Luck.
    Big Lou Thanks this.
  7. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    easy there cowboy, don't bite the hand that fed you. They both have good accounts and excellent rates. I know they won't put them on new carriers, I wouldn't either, risking the account over a newbie.
  8. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    BNSF, TQL, CH Robinson, Landstar, Pepsi, Allen Lund, etc will all take you right away. Most of the smaller brokers don't seem to care.
    Others will take you after 1-3 months -- Coyote, Western Express, etc.
    If you post a truck in a high-demand area, brokers that wouldn't normally use you will often make an exception. And once you've hauled 1 load for them, they'll use you again and again.
    Also if you ask to use agents as references along the way it helps. A broker that says "Aw, you've only been in business 4 months, I don't think we can use you." will almost always change his tune if you hand him a list of 10 references from the last month or two...
    POINTDEXTER Thanks this.
  9. Big Lou
    155
    25
    Aug 15, 2013
    Tampa, Florida
    Thanks for all the positive feedback
  10. Jerzy
    Jerzy Light Load Member
    78
    22
    Apr 11, 2012
    New jersey
    I was running on a friend authority for a couple years and just recently reinstated mine.for the most part I've had no problems.i have been told by a couple brokers that they could not use me because I was recently reinstated even though they knew who I was.
