Going to orientation, what to expect?
Discussion in 'Prime' started by slimlady1, Apr 7, 2015.
  1. slimlady1
    slimlady1 Bobtail Member
    17
    16
    Mar 17, 2015
    After reviewing the forum for a little while I realized that the questions I have to ask have not been asked or addressed, so here goes.
    I begin orientation and training soon. I currently hold a class A with a tank endorsement.
    I understand that there will need to be a road test. My question is what speed transmission do they use for this? I have very little experience on a 10 speed. I haven't been in a truck for over a month. I'm not nervous but I am concerned what the outcome would be if I don't do well. I'm assigned to a class C which means I'll need to accumulate 40,000 combined miles. Would doing sub par, mediocre on a road test have any affect on this and would doing well have any affect also?
  3. Thediamond13
    Thediamond13 Light Load Member
    115
    55
    Dec 2, 2014
    Salt Lake City, UT
    it depends on what the company has. we use both 10 and 13 speeds but it depends what truck the driver will go into. Get on youtube and there is a short video that goes over the gear pattern.
  4. Chucktshoes
    Chucktshoes Medium Load Member
    623
    542
    May 23, 2014
    Memphis, TN
    Prime uses 10 spd trannies in all of their trucks. Whatever you do in a Prime truck will be in a 10 spd. Beyond that I don't know as I came into Prime through the PSD program and acquired my license through the in-house training program.
    Edited to add- i wasn't aware there were any 13s in the fleet. I know you won't encounter one on the training yard in Springfield.
  5. slimlady1
    17
    16
    Mar 17, 2015
    I understand. Have driven a 10 before. Just wanting to know what would be the outcome on a test I don't do so hot on.
  6. CruisingAlong
    CruisingAlong Medium Load Member
    374
    441
    Oct 17, 2014
    Tampa , FL
    I assuming you won't be floating the gears? The 10 speeds seem to work very well starting off in 2nd gear, accelerating to 14-1500 step on the clutch, allow rpms to drop to 1300 and drop back into gear. If you can think in your head... lift throttle and pull into neutral... quick pause then drop into the next gear. After 5th, flip high range and go back to where 1st gear location would be. Like others said, study the shift pattern.
    When decelerating, lift throttle, slow until rpms get down to 1100 , clutch, go to neutral, rev to 1400 and drop into next lowest gear release clutch.
    One thing to note, when shifting , only depresess clutch pedal a few inches. You only take it to the floor when at a stop and going into a gear. On the road test, don't shift into neutral and coast to a stop, try to keep it in a gear at all times.
  7. slimlady1
    17
    16
    Mar 17, 2015
    Do I get sent home if I screw up double clutching or miss gears?
  8. Judge
    90,032
    Most 10 speeds shift on a 1 - 2 count.
    As you shift just do the count.in your head.
    Down shift varies between 300 or 400 RPMs on tach on straight 10s
  9. 315wheelbase
    315wheelbase Heavy Load Member
    783
    602
    Oct 26, 2014
    for a road test always start in 1st gear,,some trucks will do OK starting in 2nd or 3rd but you will not know until you drive the truck how well it will do,,9spd,10sd are about the same a 13spd , 15spd and 18spd will have a splitter button and you should be able to split gears OK,,as long as your don't grind gears and force the trans in gear you should do OK,,progress up and down the gears and take your time, think about what you are doing, remember they number the gears 1, 2, 3, 4 etc for a reason,, double clutching is easy again THINK ABOUT WHAT YOU ARE DOING AND DON'T GET IN A HURRY
  10. slimlady1
    17
    16
    Mar 17, 2015
    Thanks you guys. I called my former school and put in for an hour and half lesson this week before I go.
    123456 Thanks this.
  11. PChase
    PChase Road Train Member
    1,334
    614
    Sep 16, 2012
    Show Me State
