grinding sound when releasing gas peddle... helpppp
Discussion in 'Volvo Forum' started by damiralikadic, Jul 7, 2012.
  1. damiralikadic
    damiralikadic Bobtail Member
    5
    I have a 2004 Volvo 670.... been hearing really bad grinding noise when releasing gas peddle. It only happens when going over 40 MPH...
  3. CenutryClass
    CenutryClass Road Train Member
    1,539
    859
    Feb 15, 2006
    Do you have a 13 speed? I have a replacement like the one in my sig and it does it sometime too..
    If im in 10L and do a button shift to 10 high it grinds sometimes so I have to double clutch to get the rpms down and for it to get in gear. couldnt tell you why though.
  4. damiralikadic
    5
    I have a 10 speed and I have tried that but it doesn't work....
  5. Dna Mach
    Dna Mach Road Train Member
    3,288
    3,109
    Aug 8, 2008
    Texas
    Look under your truck by the differential and see if there is a rod hanging loose. That's your leveling rod. If it is broken you can easily zip tie until a replacement can be had. A broken leveling rod will create the exact same symptoms you described. Let us know what you find.
    VisionLogistics and 123456 Thank this.
  6. damiralikadic
    5
    That is exactly what I thought was wrong so I replaced the rod but its still making the noise
  7. jaielv
    jaielv Light Load Member
    62
    12
    Dec 30, 2010
    joliet,il
    make sure u have the correct height.had same problem I cut the rod 1 inch and noise went away.just get the spec for your vehicle height before u cut the rod.
  8. bravoo67
    bravoo67 Light Load Member
    252
    35
    Mar 15, 2012
    Brooklyn NY
    had the same problem after changing suspension leveling valve, when adjusted properly noise went away.. my height is 7.5" from the middle of the axle to the bottom of the frame.. Have 610 with 24.5 rims and 630 with 22.5 rims and this height seems to be the same on both trucks.. good luck
    Guf Thanks this.
  9. Mlaz Bogdanci
    Mlaz Bogdanci Light Load Member
    58
    11
    Feb 5, 2012
    Santa Monica , CA
    On my truck it was the drive shaft causing this kind of vibration.The yoke right after the carrier bearing had a little play and i constantly had vibration after releasing the gas pedal at 62-67mph.I changed everything else bearing,leveling valve,adjusted air ride height,new rod,2 new air bags,new shocks,8 new tires and the darn truck was still vibrating.I finaly changed the yoke got a new u-joint and got the driveshaft balanced and vibration is gone.Good luck
  10. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    I had this problem, turned out that I had the air suspension dumped. Check your airbags?
    Sent from my GT-P3113 using Tapatalk 2
  11. bossboy2
    bossboy2 Light Load Member
    264
    60
    Aug 20, 2011
    Houston, TX
