GVWR?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Powell-Peralta, Dec 14, 2010.
  1. Powell-Peralta
    Powell-Peralta Road Train Member
    1,585
    240
    Jul 17, 2007
    What does GVWR mean for the tractor?
    Actually, might as well discuss GCWR and all the other G codes.
  3. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    GVWR=Gross Vehicle Weight Rating, Maximum load of vehicle and load.
    GCWR=Gross Carrying Weight Rating, Maximum load that the vehicle can carry.
    When you take your CDL Test, these answers are in the study book you can obtain from your loacal DMV
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    There's a plate or sticker in your door jamb that gives you them numbers.
  5. ronin
    ronin Road Train Member
    2,928
    1,710
    Jul 22, 2008
    San Antonio, Texas
    GCWR is Gross COMBINED Weight Rating, for info, and indicates the maximum weight of the vehicle and its cargo combined.
  6. Powell-Peralta
    1,585
    240
    Jul 17, 2007
    Bascially, what i'm trying to get at is i saw on one tractor (don't remember which one---it could have been a K-100 or a freightliner columbia) the GVWR was 52,000 lbs.
    i know you guys said gvwr means max load + vehicle weight, but as you know we can and do go to 80,000lbs. What does the GVWR really mean? In other words, could a tractor have a lower GVWR and still do ok?
  7. josh.c
    josh.c Road Train Member
    1,105
    420
    Feb 22, 2009
    Knoxville, Tn
    In the case of a truck-tractor, the GVWR on the build plate is the GVWR for the tractor as a single unit, just as if it was a straight truck not pulling a trailer.
    Picture a truck with a cab and bare frame rails. Now picture that truck with a bed on the back with a load on it. That truck with a GVWR of 52klbs can weigh 52klbs and not be over its GVWR. Now picture the same truck with a fifth wheel on it with a trailer hooked to it. That truck, as one unit in a truck/trailer combination still has a GVWR of 52klbs. As long as the tractor, as one unit, isn't over that 52klbs, it isn't over its GVWR. Does that make sense?
  8. MercerDriver
    MercerDriver Light Load Member
    69
    7
    Sep 3, 2010
    Atlanta, GA
    LOL.... yeah, they SHOULD be in the study book
