HAzmat placard fell off on-route after my on-route inspection ,how am I getting in
Discussion in 'Questions From New Drivers' started by mcmanly, Nov 16, 2014.
  1. mcmanly
    mcmanly Light Load Member
    175
    47
    Sep 22, 2012
    NE PA
    Trouble.
    I even have my on-route inspection logged 2 hours into driving as on-duty not driving ,it was properly secured an all but somehow managed to come off . This is bullcrap ,and I have no clue how it could have came off.
    EDIT:I should note I did another on-route inspection 15 min in ,before people yell at me.
  3. lcfd15
    lcfd15 Medium Load Member
    678
    403
    Sep 17, 2014
    Dallas/Ft. Worth, TX
    contact your dm or whoever you need to for night/weekend and let them know what happened. explain it all. They might just route you to get some placards by a TS and apply them temporarily to get the load delivered.
  4. mcmanly
    175
    47
    Sep 22, 2012
    NE PA
    How much trouble am I in if I run without?it was only the one on my right side.
  5. lcfd15
    678
    403
    Sep 17, 2014
    If you get stopped by police or DOT it depends on what kind of mood they are in. They will ask you when your last stop was, did you check your placards, and so on.... I would call your night time management and report it AS SOON as you figure it out. Let them be the ones to make the "decision" and if they do it and you have a qualcomm, tell them to send you a qualcomm message with instructions on what to do so that way there is a log of what they told you.
    hal380 and bubbagumpshrimp Thank this.
  6. david123abc
    david123abc Heavy Load Member
    839
    784
    Feb 2, 2011
    Augusta, GA
    Stop at the next truck stop and buy a placard. If you just need a generic "corrosive" or whatever, you're good to go. If you need a numbered placard, buy some numbers and stick them on. I don't think that it is 100 kosher according to the regulations, but sometimes you make do in a pinch.
    bubbagumpshrimp, baha and hal380 Thank this.
  7. Nukem
    Nukem Road Train Member
    1,237
    1,447
    May 11, 2014
    Why don't you have at lest one extra placard? I always ask for 1 or 2 extra when I haul a HAZMAT load. But then our trailers have the placards holders so we don't have to stick them to the side. but then I have had 2 fall off while in transit, hence why I ask for extras.
  8. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    It is on the right side of the trailer, The other placards are in place, the right side is the one that faces the coop...... You don't think that they may notice the ones on the front and back? It is only a couple of bucks to get one at a truck stop. Come on man think for yourself, it is your license that you need to protect and it is only a few dollars. Is your license worth more than that?
    I do a lot of oversize loads and even though the company provides the flags and banners, I have my oversized bag that I throw in the truck with 2 oversized load banners, 4 flags and 4 flags on sticks along with a bunch of bungies. I am NOT going to get a fine, period.
    hal380 Thanks this.
  9. Stormdriven
    Stormdriven Medium Load Member
    331
    217
    Mar 11, 2014
    south, central, US.
    Remove the front or rear placard and put it on the side position.
    Move to a truck stop to get a new replacement placard.
    Sometimes a shipper will give you an extra if you ask.
    Placards can be secured in place with clear packaging-tape.
  10. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    Over a $1000 fine.
    Spend your 2.99 on that placard -.-
    double yellow Thanks this.
  11. tucker
    tucker Road Train Member
    12,647
    40,423
    Jun 13, 2008
    IN
    Those slide in placard holders suck if you get thin stick on placards. I either tape them in the holder or just stick them on the trailer
