Hazmat with Prepass -When to stop at scale house?
Discussion in 'Experienced Truckers' Advice' started by insipidtoast, Mar 23, 2020.
  1. insipidtoast
    insipidtoast Heavy Load Member
    991
    661
    Nov 22, 2016
    Planet Earth
    I’m not sure I remember correctly:
    When given the green light bypass signal on my prepass I can bypass the scale unless in Arizona, Arkansas and Ohio.
    Is this correct?
  3. Valuable Asset
    Valuable Asset Light Load Member
    98
    293
    Feb 28, 2020
    Great topic for debate. I always wondered if they knew those signs were out there.
    Reason for edit: Misspelling
  4. mustang190
    mustang190 Road Train Member
    2,844
    6,111
    Jan 18, 2011
    Florida Panhandle
    What does the sign say?
    If it mentions a exception for hazmat, then you pull in.
    truckdriver31 Thanks this.
  5. Dna Mach
    Dna Mach Road Train Member
    3,263
    3,008
    Aug 8, 2008
    Texas
    Had a driver with my company years ago bypass the Arizona scale at Havasu City on 40 East years ago. Got the green but was placarded. Got a ticket and called to see how much it was. He was told he had to appear in person. Called a lawyer that appeared for him. Was $3500 dollars when it was all said and done.
    You definitely want to know the rules before playing.
    http://prepass.com/wp-content/uploads/2016/04/Bypass-Restrictions-040816.pdf
    spindrift Thanks this.
  6. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    always follow the sign on hazmat and oversize
    mitrucker Thanks this.
  7. Truckermania
    Truckermania Road Train Member
    1,165
    1,754
    Oct 13, 2011
    Sturgis,SD
    When in doubt, go in. Better to go in and not need to than not go in and get chased down.
  8. LDLWells
    LDLWells Heavy Load Member
    782
    1,217
    Jan 14, 2019
    I was told by a weigh station they have a hazmat quota so they pull them all in to make sure they meet it
  9. shatteredsquare
    shatteredsquare Road Train Member
    1,403
    1,832
    May 23, 2014
    middle dirt
    If hazmat in Arizona, Arkansas or Ohio you pull in regardless, unless scale is straight closed. No matter what your beeper says or the bypass sign says.
    Also if you drive the exact to the 0.5 mph posted speed limit over the little scale bars before the guard house there is a 90% more likely chance they'll green light you through the bypass lane. It's a speed test
    James j and insipidtoast Thank this.
  10. kemosabi49
    10,594
    45,292
    Jan 13, 2013
    SW Arkansas
  11. shatteredsquare
    1,403
    1,832
    May 23, 2014
    middle dirt
    Noooooo Ohio is 100% hazmat pull in, unless scale is closed, they even have the extra signs up, 'hazmat loads pull in'
    Deadwood and tscottme Thank this.
