headlights adjustment
Discussion in 'Volvo Forum' started by me myself and I, Dec 16, 2013.
It's a simple external torx socket available at any auto parts store. The size you need is an E8.
The Volvo headlights are pathetically weak and adjusting the aim will do no good, if that is what you are trying to do. -
I would buy yourself a multi-bit screwdriver set for the truck as most your dash screws are torx, tail lights are usually phillips head if not riveted. It's handy to have on a truck. I have a Husky set I bought at HomeDepot. Lowes sells the Kobalt brand which is good and of course Craftsman is decent enough for the truck. Almost any set will do. Auto Parts stores sell them, even truck stops but I hate their over priced cheap stuff.
You can eyeball it but the proper method is in a shop manual diagram which you might find on the internet. You want to be so many feet like 5 or 10 feet from a wall and you measure two X's so high and so far apart to get it back to factory if they were tampered with.
Like Dna said Volvo's are known for poor headlights. A lot has to do with the poor metal reflector shield inside the light housing and the lens discoloring. -
My adjusting screws ends look like ends of torx screwdrivers. Its '07. What I look for is something like a socket.
e8 is the correct size socket.
Will look for it. Thanx guys.
If you don't have a torx I just used a socket, 7mm I believe. Raised it up about 10 half turns and it seemed to do the trick.
Pmracing Thanks this.
