Heard/Experianced something today that was strange...
Discussion in 'Ask An Owner Operator' started by Hystorm, Jun 8, 2022.
  1. Hystorm
    Hystorm Bobtail Member
    Jun 8, 2022
    So, for most of my life, I've been into Radios and Wireless Tech.
    For a long time there I was amazed and in awe of how antennas work.
    In any case, did a 400 mile road trip today on I-15.
    I was listening to an AM talkradio show most of the time.
    EVERY 18-Wheeler I passed completely blocked out my signal and filled the car with electronic noise!!
    WTF have you guys installed in most of those now-days?
    Is it Satellite equipment to track the trucks or what is going on with modern rigs and all the electronic noise!!??
    Seriously, EVERY truck I passed blasted me with this tech noise....There were a few that were SOOO powerful, I had to turn off the radio for a min.
    Rideandrepair and tscottme Thank this.
  3. Lexuslane
    Lexuslane Medium Load Member
    496
    1,009
    Oct 22, 2021
    I think it’s the ABS or the lane departure and collision warning .
    I’ve heard it too, I occasionally listen to AM talk stations but can’t stomach the commercials so usually hit a podcast .
  4. tscottme
    tscottme Road Train Member
    If you are listening to AM radio I suspect the trucks power inverters are interferring with your radio reception. I know as a truck driver that every truck I've driven with a power inverter has terrible AM reception until I turn off the inverter. A power inverter converts 12 volt DC power into 1110v AC power to power devices like microwave, TV, etc. I've also had a Volvo about 10 years ago and the LED marker lights seemed to interfere with AM radio deception. I used to be a big fan of what's called DX-ing or listening to distant AM radio stations.
  5. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    [QUOTE="tscottme, post: 11991251, member: 19119"12 volt DC power into 1110v AC power .[/QUOTE]
    Yikes 1110 volts holy zap batman lol
  6. Judge
    87,961
    It’s kinda like going from Analog Tv to this Digital.
    I just have Antenna at home, every time a car goes by the dirt road i live on, tv goes off for a second.
    They forced us to go to digital because it was so much better, like Dish every time it rains the darn thing went off.
  7. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    +1 on inverters, plus nearly everything plugged into them. Some of the worst offenders are usb bricks and other charging appliances. LCD flat panel tv's have a similar transformer inside. Nearly all made in China and very dirty RF emitters. They cut production costs by eliminating or reducing shielding that would prevent noise. Nobody usually notices or cares, as nearly all this stuff is intended for home use where it will be spread out over a larger area.
    Pro tip: that noise will also scramble a digital tv antenna signal. If your tv picture is turning into digital soup now and then, it may not just be passing traffic blocking signal. Move any chargers as far away as you can from the tv, antenna and cable, and turn off/unplug any not being used.
    Pro tip 2: Cheap HDMI video cables can be dirty with RF noise too. Streaming devices, dvd players, game consoles. Trash the HDMI cables they come with, and replace with name brand, well shielded ones. Doesn't hurt to also turn that stuff off and unplug it when not in use.
    Most surprising one I seen? The light in my microwave. One day I forgot to turn off the cb when parking. I stow bread and chips inside the microwave. When I opened the door to get a couple slices of bread for a sandwich, the cb went nuts with hash noise. Closed the door and it went away. It must be a dc lamp fed off a crappy transformer.
    D.Tibbitt and gentleroger Thank this.
  8. Hystorm
    Jun 8, 2022
    Roger, thanks all.
  9. Ridgeline
    22,417
    116,623
    First understand that the radio system (am/fm-cb) in factory trucks are marginal at best, they are setup for a selling point to the customer, nothing else. Worst am/fm radios on the market are usually OEM radios. The antenna system is at best a compromise between cost and performance.
    second the truck manufacturers are using components which actually are noisy. The shielding designs of the ecm, body and abs modules are horrible and produces two types of interference - what is called ultrasonic static and the other is called spurious radiation, both can reach up to the fm band and surely wipe out am and cb reception.
    So as a truck passes you, it is the fact that you are hearing signals coming from the trucks electrical system itself and it is blocking signals from the am stations because of the noise it creates and because of what I said in my first paragraph.
    now not to forget one other thing, internal noise. I have a lot of chargers like the one that came with rand McNally nav units and a few xm radio receivers that were extremely noisy. These were removed and replacements bought that were quiet. These were so noisy that they came over the fm radio when there was a weak signal.
    RedForeman Thanks this.
