Heavy vibration when I turn on engine brake
Discussion in 'Ask An Owner Operator' started by Moephilly1, Jan 12, 2019.
  1. supersnackbar
    19,345
    48,382
    Aug 19, 2007
    Your Town, USA
    CAT might do it different than Detroit. I might be remembering it wrong, but Detroit use to use the center 2 cylinders for low, the front 2 and back 2 for med (middle 2 off), and all 6 for high. If it does it on all 3 settings, then my advice doesn't help much. Kinda odd.
    Moephilly1 Thanks this.
  3. snowwy
    snowwy Road Train Member
    20,567
    13,292
    Jul 6, 2009
    I was taught that jakes rotates. Not cylinder specific. 1 cylinder, 2 cylinders, 3 cylinders.
    I also have a 07 w9. The truck is VERY picky about the quality of fuel. And vibrates when it hates the fuel. Does both jakes AND full throttle modes. Some poor fuels aren't as bad as others.
    As for pulling the codes. Turn cruise switch off. Hold the resume switch down about 5 seconds. Engine light will flash. Count the flashes. 5 flashes with a breif pause and 5 more flashes. You'll always get a code 55. If the light is off. That's standard operating procedure. Everything is working. If the light is on, It'll flash whatever codes you got ACTIVE. My common numbers are 93 and 94. Intake valve actuators for cylinders 3 and 4. It's been a few months for me now so the problems must be fixed. FINALLY.
  4. Moephilly1
    Moephilly1 Light Load Member
    111
    35
    Oct 6, 2016
    Yea it does it on all three. But thanks for your concern
  5. Moephilly1
    111
    35
    Oct 6, 2016
    It feels like your talking about my truck lol. I have the same exact problem with fuel when it doesn’t like it, it vibrates and throws a little white smoke from pipes and loses power. I have no codes now but I had 93,94 I changed the actuator for #1,#2 but it didn’t make a difference.
  6. snowwy
    20,567
    13,292
    Jul 6, 2009
    93 and 94 are supposed to be cylinders 3 and 4. And might not be the actuators but the plugs themselves. I know the actuators were never replaced. And if you dig in to google enough. There's posts of wiring issues.
  7. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    You don’t need to read the flash code while it’s happening. It stored it in the computer for you. Turn key on, make sure cruise control is switched to “off” then just hold down “resume” switch until the 2 digit flash codes start flashing via check engine light
  8. snowwy
    20,567
    13,292
    Jul 6, 2009
    It stores codes in computer but only flashes ACTIVE codes. So if the problem happens to be working. No code will flash.
  9. Cam Roberts
    1,621
    1,938
    May 13, 2018
    I understand that. But the active code he had just for that minute will be stored and will be first code to be spit out when he pulls codes with cruise control. I had same issue with my cat today. I have old stored codes. I had a situation arise where it only happens on occasion. Check engine light started flashing a code. I shut the truck down and pulled code. Gave me the latest code first. If it was active only for a second, but problem fixed, it will be stored and will be first code to be emitted
    Tombstone69 and Moephilly1 Thank this.
  10. snowwy
    20,567
    13,292
    Jul 6, 2009
    Mine don't flash anything unless it's active. Triggering the light.
  11. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Oh these cats are good like that. If code is active. It will flash. If it problem is not active anymore, it will store the code in sequence till codes are deleted with et
