HELP GUYS OR SUGGESTIONS
Discussion in 'Ask An Owner Operator' started by thecubantrucker, Jun 9, 2020.
  1. thecubantrucker
    thecubantrucker Light Load Member
    145
    89
    Jun 2, 2019
    so 2003 freightliner century Detroit 12.7 no egr so few days ago while driving heavy load my intercooler went out hole in front started loosing lot of power replaced it and behind the air compressor I hear a hissing sound opened it up and replaced the little air lines alongside the flange that had it I can still hear some hissing sound around there and now my truck is loosing coolant checked all hoses cant seem to point out a leak . No coolant in oil and no smell of diesel in coolant also when I start it up no puff of white smoke but from time to time when taking it off in first gear or low gear I can see poof of white smoke from exhaust then turns regular dark what do you guys thing suggestions how to check or what to check
  3. thecubantrucker
    145
    89
    Jun 2, 2019
    also when starting to drive little hesitant like it's missing something or an injector feels weird idk unless theres coolant in the diesel could the air compressor cause coolant loss
  4. Rideandrepair
    17,357
    56,317
    Aug 8, 2015
    Could have a bad injector o ring. Did you replace the air compressor air intake line, from intake to compressor? Common failure, making a hissing noise, loss of Turbo boost.
    650cat425 Thanks this.
  5. thecubantrucker
    145
    89
    Jun 2, 2019
    have not replaced the air compressor now will a bad air compressor push coolant to the system ??
    Rideandrepair Thanks this.
  6. Rideandrepair
    17,357
    56,317
    Aug 8, 2015
    A bad air compressor, can push air pressure, into coolant, and/or oil. Causing Radiator to build pressure, and overflow. or excessive blow by in crank case. A simple pressure test of the radiator, will tell. If it’s building pressure, you can isolate compressor and re test. All you have to do is take SS air line off compressor
  7. thecubantrucker
    145
    89
    Jun 2, 2019
    what do you mean by ss out sorry both lines from the compressor to the manifold and block ??
  8. Rideandrepair
    17,357
    56,317
    Aug 8, 2015
    Compressor has 5 lines. 1 oil supply,oil drains out of compressor into block. 2 coolant lines from the block,1 in and 1 out. 2 Air lines, 1 in ( from intake manifold, filtered turbo charged air) and 1 out,(Stainless Steel line to air drier)
  9. thecubantrucker
    145
    89
    Jun 2, 2019
    so take that line out of the compressor the one going to the air drier and see what it does ??
  10. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,791
    Jan 17, 2017
    Check your fuel tank for pink fuel if you have red coolant.
    Check your fuel filter and see if it has a coolant-fed heater.
    Check your fuel tank again and see if you have a coolant-fed fuel tank heater.
    After that you might consider a Dyno. I think a dyno can help rule out bad injector cups or a cracked head, without opening the engine.
  11. bad-luck
    bad-luck Road Train Member
    3,317
    6,097
    Nov 16, 2013
    Baltimore, Maryland
    Coolant only has a few places to go... out of the stack, on the ground, a leak, in the oil, out of the overflow tube in the radiator. How much are you loosing? Start here, put a Gatorade bottle on the overflow tube to see if you are loosing it there
    Coffey and Farmerbob1 Thank this.
