Help, I accidentally drove 125 miles with inter axel and diff locked!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tylerdurden, Mar 11, 2019.
  1. Tylerdurden
    Tylerdurden Bobtail Member
    12
    17
    Mar 11, 2019
    I was driving a tandem Kenworth tank truck, unloaded (Early to mid 2000's I believe) and got stuck in a snow filled yard. I had to lock up the inter axel as well as both diff's to get unstuck once. I then carried on working there outside the truck for a few hours before driving home. It wasn't until I got all the way home (About 125 miles, 10% grid and 90% highway) before I realized they were still locked.
    There was no light on the dash or any other warnings. I didn't notice any issues when trying to steer, but I only had to make a couple 90 degree turns during the drive. Now I'm concerned with what kind of damage I may have done. The tires on both axels are all the same make and put on new together.
    I accept the fact that there was unnessary wear on the tires and drive train, but if everything seems to be fine now and I didn't snap anything, does that mean I should be in the clear as far as a catastrophic breakdown/failure?
    Fingers crossed, Thanks for and and all insight!
  3. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    You should be fine. I have left power divider in, on trucks i have owned, and not had issues.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Your fine, relax.
  5. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,792
    Jan 17, 2017
    Watch your hub seals carefully for leaks. I know some model Kenworths can lose seals on hubs if the differential is locked at highway speeds. Factory defect on certain models, if I remember right. I lost two seals on a 2015 Kenworth T680 when I took a heavy load out of an icy yard and didnt switch off the differential lock.
    Hub grease has a strong earthy scent, at least the stuff in that Kenworth did.
    Tombstone69 Thanks this.
  6. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    They usually don't start breaking down until they get hot(after a couple thousand miles)if it didn't get hot you should be fine, but you should rig some kind of light or buzzer so you know it's engaged. The one I drive has a light on the ceiling console that shows the rears, so far I've left it in at least a half a dozen times. The driver before me blew up 3 front rears and a PTO in 20yrs of driving.
    Farmerbob1 Thanks this.
  7. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I drove 3500 miles locked...no problems.
  8. Oxbow
    Oxbow Road Train Member
    13,378
    138,602
    Nov 24, 2015
    I believe your lockers may only work on the low side of the transmission, or only up to a certain speed, so no problem there. The power divider probably caused a bit of accelerated wear, but no problems.
    SAR Thanks this.
