High crank case pressure
Discussion in 'Kenworth Forum' started by RBT, Jan 5, 2015.
  1. RBT
    RBT Bobtail Member
    8
    I bought an 08 kenworth c-15 cat 2 weeks ago. It keeps putting high crank case pressure code and derating engine. I have changed blowby filter, crank case pressure sensor, and still having problems. No visible blowby. Have had back to dealership twice, nothing shows up on computer.
    HELP!!
  3. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    Have dirt daubers invaded your draft tube?
    RBT Thanks this.
  4. RBT
    RBT Bobtail Member
    8
    no checked all the lines
  5. Cat sdp
    Cat sdp . .
    20,975
    73,109
    Apr 8, 2012
    Orion's Belt
    Have you gotten to the dealer with the code active...?
    And a cat house is probably your best bet.
    RBT Thanks this.
  6. RBT
    RBT Bobtail Member
    8
    yes it was active and nothing shows up,both times
  7. RBT
    RBT Bobtail Member
    8
    it only does it when under a load
  8. BeenJammin
    256
    118
    Dec 17, 2013
    Can you elaborate on active and nothing shows up?
  9. Cat sdp
    Cat sdp . .
    20,975
    73,109
    Apr 8, 2012
    Orion's Belt
    How many miles on it and what is it? Usually a new filter straightens them out.
    And the the dealer is clueless . Gotta love it.
  10. BeenJammin
    256
    118
    Dec 17, 2013
    Maybe dpf needs a good cleansing, where it disappears, oops, my mistake.
    Brickwall Thanks this.
  11. Judge
    87,737
    The Engine Control Module (ECM) activates this code when the crankcase pressure has exceeded the limit for a programmed time period. The amber warning lamp is illuminated. The code is logged. Engine power is derated.
    This code can be caused by an obstructed tube, an obstructed filter (if equipped), or an obstructed hose. Also, a plugged OCV system will cause the code.
    Plugged OCV System a plugged OCV system will cause excessive crankcase pressure, check the OCV for plugging.
    Faulty Check Valve can cause excessive crankcase pressure. A faulty check valve will not allow the crankcase to vent properly,replace the check valve.
    A plugged disposal tube will not allow the crankcase to vent properly check the disposal tube for obstructions.
    Faulty Sensor
    Connect Caterpillar Electronic Technician (ET) to the service tool connector.
    Turn the keyswitch to the ON position, But Do NOT start the engine.
    Remove the oil filler cap. Monitor the crankcase pressure in Cat ET.
    Or
    Internal Engine Problem
    Damaged pistons or rings can cause too much pressure in the crankcase. This condition will cause the engine to run rough. There will be more than the normal quantity of fumes (blowby) entering the OCV system. The OCV system can then more quickly become restricted, causing oil leakage at gaskets and seals that would not normally have leakage. Blowby can also be caused by worn valve guides or by a failed turbocharger seal.
    To determine whether the piston rings leak, measure the crankcase blowby. Use the following service tools, along with Software License, NETG5044:
    285-0900 Blowby Tool Gp (SMALL ENGINE)
    348-5430 Multi-Tool Gp
    Cat sdp Thanks this.
