Hollow whistle and screeching noise
Discussion in 'Ask An Owner Operator' started by kay_ray, Oct 1, 2020.
  1. kay_ray
    kay_ray Medium Load Member
    486
    1,206
    Jun 6, 2019
    hey guys so i have this high hollow whistle type noise coming from engine when the rpms are high and sometime when manifold pressure is close to 30 psi. Its a cummins isx15 with 420,000 miles on it. You can hear it clearly at 3 sec and 25 sec mark in video
  3. 201
    201 Road Train Member
    12,370
    25,270
    Apr 16, 2014
    high plains colorado
    I didn't hear it well, but turbos make a screeching noise when they go south. Is oil dripping out the bottom of the turbo? If the bearing goes, it usually takes out the seal.
    kay_ray Thanks this.
  4. kay_ray
    486
    1,206
    Jun 6, 2019
    No oil dripping . No oil pressure or power loss. .does the bad engine belt make that noise too ?
  5. snowwy
    snowwy Road Train Member
    20,560
    13,286
    Jul 6, 2009
    Could be a bearing noise from alternator or idle pulley also.
    Connect Bluetooth to radio you can hear the sound better.
  6. 201
    12,370
    25,270
    Apr 16, 2014
    It may be a bit intimidating, but nothing will happen. Open the hood, and find the throttle or have someone rev the motor, and listen to the motor. ( be careful of the fan) You might hear it, only quieter. Probably not a turbo, more likely a pulley or belt tensioner like snowy sez.
  7. Judge
    88,053
    Like my old boss once said.
    “Keep going, it’ll show itself eventually then you can fix it.”
    feldsforever and kay_ray Thank this.
  8. kay_ray
    486
    1,206
    Jun 6, 2019
    I think that too. Going to change both belts and pulley today . If it still happens turbo is coming off. And one more thing this sound is pretty loud with jake brake on full with one lower gear .
    201 Thanks this.
  9. kay_ray
    486
    1,206
    Jun 6, 2019
    Ahaha i try to keep everything up to date and change before they fail .
  10. Judge
    88,053
    I’ve also heard, “If you’re not tearing something up, you’re not working.”
    feldsforever, 201 and stillwurkin Thank this.
  11. 201
    12,370
    25,270
    Apr 16, 2014
    That's an old farmer saying, "if it doesn't break, you ain't workin", and it's true. Farmers go from one break down to the next.
    650cat425 Thanks this.
